ASD Relay clicking
  • 1 Post By rob342
Old 09 Nov 2014, 07:52 pm
Default ASD Relay clicking
I have no idea where to go. I'm a former tech but completely lost. I have a friends 01 PT limited with 2.4 non turbo. The car ran perfect when he parked in his garage and when he came out a few minutes later the car wouldn't start. It made a hideous noise while cranking as if there was some metal contacting inside. My first thought was timing belt. But that's not the issue I'm struggling with. There was a continues fast clicking coming from the engine compartment after this. It would only stop when the battery was disconnected. It turns out that the clicking was coming from the EGR solenoid, IAC motor, and ASD relay. The ASD relay was constantly cycling on and off. With the key on, the AC and fuel pump relay also cycle like this but they stop with key off. The computer is sending the pulsing signal to the ASD (and the other 2 relays). A logic probe on the ASD ground terminal to the ECM is pulsing. WHY? It seems as though the output side of the ASD circuit is fine but what inside (or outside) the computer is involved in this circuit that might cause the cycling?
LOST
Old 09 Nov 2014, 08:01 pm
Default Re: ASD Relay clicking
Clicking or buzzing relays is a text book symptom for a bad ground. These cars are notorious for sensitivity to bad grounds as well as failing batteries. Check the obvious grounds as well as the hidden ones in the inner fender wells and properly test the battery first. Let us know what you find.
Old 26 Nov 2014, 12:14 pm
Just wanted to update for the greater good of the community. We took the car to the dealer who said,
"your battery is bad and your flywheel is broken. It'll be a million dollars".
I said,
"NO! start with the battery."
300 dollars later they said,
"Well, maybe it isn't your battery or the flywheel". They checked it out for a week or so and then said, "We think it's your computer. It'll be a million bucks."
I said "Go F yourself" and took the car. I got a new PCM from Autozone for about $250, installed it, and POOF! the thing started right up. So, If anyone has their relays going berzerk it might be your computer but make sure you properly diagnose it first. How to do that without a direct line to Chrysler, I have no idea.
Old 26 Nov 2014, 12:33 pm
Interesting - I had no idea Autozone sold PCMs - they program your VIN in it?
Old 26 Nov 2014, 09:47 pm
I would suggest checking to see if your PCM is grounding the ASD relay with the ignition off. Something is sending a signal to the ASD Relay. You need to find the ground wire from the PCM to the ASD Relay, check the ground wire with the ignition on and then with it off. If it still has ground with the ignition off you need to disconnect the ground wire at the PCM and see if it goes out. If it doesn't then check for a short to ground on the wire. If it goes out then its time to check out why the PCM is supplying the ground with the ignition off.
Old 26 Nov 2014, 10:56 pm
He solved his problem with a new PCM...
Old 27 Nov 2014, 12:05 am
not4ne1 Re: ASD Relay clicking
Quicksilverdon,
You need to read what he said. He was asking how to diagnosis it so that it might point to the PCM. he didn't know how to diagnosis it even after Chrysler told him it was the PCM.
Old 27 Nov 2014, 12:12 am
Quicksilverdon,
You are correct. I was wrong. Sorry.
Starter clicking not turning rcalzadilla Tech & Performance Forum 2 06 May 2014 03:07 pm
Just clicking pingis Tech & Performance Forum 10 03 Jan 2014 01:26 pm
Clutch Clicking Terrib11 Tech & Performance Forum 7 09 May 2012 06:49 pm
clicking in wheels veno3122 General PT Cruiser Discussions 0 10 Jun 2011 09:45 am
Clicking on my PT? Help PLZ! CruseadorPT Tech & Performance Forum 2 30 Jul 2009 07:32 am
