What Transmissions interchange with 2002 Limited?
Old 11 Nov 2014, 03:37 pm
Default What Transmissions interchange with 2002 Limited?
Hi All, I am new to the forum, and I hope someone here is able to help me. Have a 2002 PT Cruiser Limited, and transmission slipping badly. 190,000 miles. Looking to possibly find replacement transmission from a salvage yard. What other years fit this particular model? Any help appreciated
Thanks
Old 11 Nov 2014, 04:22 pm
Default Re: What Transmissions interchange with 2002 Limited?
couldn't say, but for others, auto or stick?
2016 Kia Soul Plus Black
Old 11 Nov 2014, 04:28 pm
cruserdad1976's Avatar
I can tell you a stratus will fit into a 06 auto id say just call a salvage yard they will know exactally what will fit mine was someware in the 225-300$ range with like 60,000 on it
myckee likes this.
Old 11 Nov 2014, 05:09 pm
its an automatic.
Old 11 Nov 2014, 06:07 pm
Any car with a 41TE transmission. Here is a pic I snagged from rockautos site. I looked up a 2002 pt cruiser auto trans and this is the list from the part number.
Old 11 Nov 2014, 06:42 pm
you need to be very careful about what your are reading....
As you area new member I would recommend to call a local "Transmission service shop" and have them explain a little better about what you are looking for.
If you don't please don't be surprised when things don't work out so well for your project!
Old 11 Nov 2014, 09:09 pm
Handy_Cruiser's Avatar
Thanks
myckee's list above looks about right. Chrysler used that 41TE in a lot of cars. But you will need to make sure it was originally mated with the same 2.4 engine. I changed out one of these on my Sebring and then rebuilt one myself. The guts are the same but there are several shells with different bolt patterns to fit different engines. The good thing with these is that if everything looks the same, then it usually is as long as you stay within the year models indicated in that list.
When looking for one at a salvage yard, the best bet is to find a car that was in a collision. That way you know it was going down the road when it died. Also, pull the pan and see how full it is of metal shavings. A good tranny will have a small amount, but a bad or warn tranny may have a lot. You can't judge if a tranny is good this way. But you can sure spot a bad one like this.
Above all, make sure you get a warranty. Even the local Pick and Pull here gives a six-month warranty on transmissions. That way you can get another transmission from them without cost if you find something wrong with the first one. That will not cover labor if you hire it done. But for DIY work, you won't be out too much.
Old 11 Nov 2014, 09:15 pm
As I said this is not all the information you need to know before you go on your way to getting something that may not altogether work for you.
As an example... a 2006 NA PT Cruiser 41TE/A606 will NOT work in our (Todd your PT GT ) and mine as an example without some changing of parts!
The lists being posted are only the base Transmission 41TE/A606 only and is NOT an interchangeable chart from one model to another. And the information is also complete.
This is why I suggested to talk to a Transmission Service Shop BEFORE you waste your time and get the wrong transmission or find later that you need other parts to make it work!
Old 12 Nov 2014, 05:14 pm
Found a Transmission, out of 2005 PT Cruiser. 85,000 miles that was in a collision. Safe assumption that this PROBABLY fit right in? as is same model and only 3 years off?
Old 12 Nov 2014, 05:21 pm
PM sent
A New Zealander with a PT 2002 limited thatshistorical21 Tech & Performance Forum 7 07 Mar 2013 02:24 am
2002 PT Limited bigsmooth Tech & Performance Forum 6 21 Dec 2012 04:21 pm
2002 PT limited F/S detnight Classifieds: For Sale/Trade 4 17 Aug 2011 09:54 pm
2002 , rim interchange ? new here bob67firebird428 Wheels, Tires, Suspension 3 26 Jun 2007 01:14 pm
New member,Just got 2002 Limited tommiesc General PT Cruiser Discussions 20 17 Jan 2004 12:51 pm
