02 base driving me crazy(er)
Like Tree10Likes
Old 12 Nov 2014, 07:41 pm
Default 02 base driving me crazy(er)
Hello all!!!....new to the forum and some tech advise. Back in the summer i was able to purchase a trashed, but complete 02' cruiser for $400.....i knew it had issues but i figured, what the heck...well after head gasket, timing belt/water pump...(It took me 3 times to get the darn thing in time..lol) , tune up, brakes all around, tires, power steering hose, battery, oil sending unit, several dash/cluster bulbs....and a very detailed cleaning inside and out.....i have got her up and running good....except....its hard to start when its cold....very hard. This morning it didnt start (about 30 degrees)....later in the day it finally started, but struggled to do that....no codes, coolant temp sensor reading right.... Are these prone to fuel pump failure, or rather should i say weakness?? checking pressure is all i have not done.(got to borrow a tester)...any other ideas? Runs great after she starts, with the exception of a slight shaky idle....
Old 12 Nov 2014, 07:49 pm
Default Re: 02 base driving me crazy(er)
Your not going to like the answer. But 4 might be you lucky number.
3rcruiser likes this.
Old 12 Nov 2014, 07:55 pm
LionPT's Avatar
Someone posted a similar problem about a month ago...it ended up being the starter.
Any pics of your car...
Old 12 Nov 2014, 07:56 pm
well honestly, i can do it with my eyes closed....lol But, i just cant see that being the problem...the last time i did it, i set it...loaded the tensioner...spun it over several time...re-checked and it was dead on.. I even checked the compression before putting the upper intake back on (all cyls at 125-140psi)
Took me 4 tries to finally get the timing correct.
Old 12 Nov 2014, 07:57 pm
no pics yet...
Old 12 Nov 2014, 08:00 pm
Did you happen to take pics? Could help rule that out. If starter is rolling the engine over. Not sure how that could play in.
Old 12 Nov 2014, 08:03 pm
LionPT's Avatar
It only happens when it's cold out...I swear someone posted here awhile back with the same problem.
Old 12 Nov 2014, 08:04 pm
How many miles? Injectors might be crudded up - try an injector cleaner like Lucas - can't hurt.
767skyking likes this.
Old 12 Nov 2014, 08:14 pm
injectors seem fine... I ran a can of sea-foam thru the tank. I did remove and clean the throttle body and replaced the IAC trying to fix the shaky idle. What about plugs, and wires thoughts???...i replaced the plugs with autolite double platinum and the wires are part store aftermarkets...I also replaced the coil with a part store unit...I see alot of posts about spark plugs....seems everybody has their own prefered....
Tags
cold start, fuel pump, rough idle
Shimmy driving me crazy! red98gt Tech & Performance Forum 11 15 Aug 2014 05:07 pm
driving lamps base PT ELVIS General PT Cruiser Discussions 11 04 Nov 2013 01:16 pm
Battery driving me crazy. Where to start? JPGP Tech & Performance Forum 1 24 Sep 2012 09:46 am
Tweeter Hissing - Driving Me CRAZY JuggalotusHeat Sound and Security Forum 20 31 Mar 2011 02:45 pm
This rattle is driving me crazy! HELP! ElectricBlueGT Turbo Wheels/Suspension/Handling 6 19 Dec 2003 10:49 pm
