03 Cruiser No Spark
Like Tree3Likes
  • 1 Post By quicksilverdon
  • 1 Post By ptcruisersteve
  • 1 Post By augmenton
Old 15 Nov 2014, 02:08 pm
Default 03 Cruiser No Spark
Alright, so I've seen a number of threads about this and so far nothing has solved my problem.
Backstory: the oil pressure light would come on every now and again, then it would go away. The car had oil upon inspection. This time the light came on while out on the freeway followed shortly by the car dying. I was not in the car at the time, so unfortunately I cannot say if it had any other symptoms before its death. Unfortunately the battery died with the flashers on while waiting for a tow, wiping any possible codes. Battery has since been replaced, still finding no codes but have not been able to get the car running to actually throw any new ones.
Once towed home, I found that the car has no spark. It will crank, but not much more. The fuel pump runs, as I can both hear it and could smell gas in the intake when I opened it. I've checked and replaced several sensors and components:
-ASD relay is working
-all fuses in both fuse panels are good (checked them all just for the heck of it)
-replaced Oil Pressure Switch/Sender
-replaced CAM Sensor
-Replaced Coil Pack
-Checked voltage from ASD to Coil - found constant 12V when cranking
I have yet to check the Crankshaft sensor, but if I find a constant 12V at the ASD/Coil, couldn't I assume that the Crank sensor is working? I was under the impression that the PCM would power down the ASD if it couldn't get a signal from all sensors in the system.
I'm trying to rule out all the easier, cheaper fixes before jumping to the bigger stuff, such as a bad PCM ($$$) or a snapped timing belt (so much time and effort in the cold).
Old 15 Nov 2014, 02:43 pm
Default Re: 03 Cruiser No Spark
You can rule out the timing belt very simply (with the help of a friend). Take the Camshaft sensor off and look into the hole where the sensor was. You'll see a thing called the Target Magnet. Have someone try and start the car and if the Target Magnet turns round while the engine is turning, the timing belt is good. Doesn't move, the belt has snapped.
Old 15 Nov 2014, 02:57 pm
How many miles on your PT Cruiser?
Has the timing belt ever been replaced?
Old 15 Nov 2014, 03:47 pm
I though it could throw trouble codes even if car doesn't start, in the "trying to start" phase...
Check for codes now...
NitroPT likes this.
Old 15 Nov 2014, 03:50 pm
I believe Augmenton already tried to get codes after replacing battery.
Old 15 Nov 2014, 03:54 pm
Hey, thanks for the quick responses everybody.
I'll check the timing belt next. The car has 97,000 on it and the belt has never been replaced. So it's getting (or is already at) the point where that becomes a problem.
The car shows no codes. I hooked an OBDII reader up to it and it finds nothing. Shows nothing on the dash besides the standard light up you get when trying to start the car normally.
If I wanted to check to see if the grounds running from the PCM to the coil are sound, how would I go about doing that? If it's rapidly alternating the ground wire, then would a standard voltmeter do the job, or do I need a special tool?
Old 15 Nov 2014, 04:11 pm
This link might help you in determining if your PCM might be faulty.
http://www.justanswer.com/chrysler/5...ng-thread.html
UptownSport likes this.
Old 15 Nov 2014, 04:42 pm
Fantastic! Thanks. So next on my list is checking the timing belt and chasing pins on the PCM connector. Hopefully I find something.
Old 16 Nov 2014, 02:48 am
Keep us posted on what you find out.
Old 16 Nov 2014, 07:53 am
-Replaced Coil Pack
Is the security light on, on the dash? Little red light?
Could this be an ignition problem as in ignition cylinder?
When my PCM was bad it would turn on the CEL and have readable codes immediately after starting.
Grounds: follow the battery ground to left fender. Bad ground for my o2 sensor would throw code circuit voltage high P032 immediately after starting.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Tags
2003, dead, no spark, pcm, spark
02 Cruiser No spark oneofakinder Tech & Performance Forum 19 25 Sep 2014 02:24 pm
05 PT Cruiser, No start, No spark Rya Tech & Performance Forum 3 01 Dec 2013 03:30 pm
07 Cruiser with no spark???? halfwaydecent Tech & Performance Forum 3 10 Feb 2013 02:09 pm
01. pt cruiser no spark gjason49 Tech & Performance Forum 1 03 Jul 2011 04:08 pm
Help no spark 2002 pt cruiser zackkbcobra Tech & Performance Forum 14 27 Jun 2011 03:27 pm
