Heater acting strange
Old 17 Nov 2014, 03:27 am
Default Heater acting strange
So, I have a remote start. Now that it's getting cold I use it a lot more. I've noticed when I get in the air is cold, but when I rev it a time or two it blows very hot. Any ideas guys?
2005 Purple Pt Touring 130k Still Running Strong
New timing belt and water pump at 130k.
Old 17 Nov 2014, 09:04 am
UptownSport's Avatar
Default Re: Heater acting strange
Coolant low?
Old 17 Nov 2014, 09:13 am
I would suggest checking the thermostat.
Old 17 Nov 2014, 10:08 am
uptown, the coolant shouldn't be low. just had the timing belt done by a trusted mechanic. but i will check it.
steve, any way to check the thermo without pulling it?
Old 17 Nov 2014, 10:26 am
Read the poor fuel milage thread you also posted on.
Old 17 Nov 2014, 10:40 am
Where is the engine temp gauge at? That's the best indication.
Old 17 Nov 2014, 11:23 am
Temp gauge reads normal. that's the part that I find weird.
Old 17 Nov 2014, 11:49 am
Feel the hoses going to/from inside heater core - are they both hot? I suspect heater core has a blockage or the air vent may have a problem.
Old 17 Nov 2014, 12:17 pm
I'll have to do that after work. I hope its not a blockage. Pita to deal with. Had one on a ranger I used to own.
Old 17 Nov 2014, 10:11 pm
I would suggest taking the radiator cap off when the engine is cold, start it up and when it reaches normal temperature see how good is the coolant flow is in the radiator. Then rev it a time or two as you usually do and then let it idle and see if there is a big change in the coolant flow.
Radio/Nav system acting strange lenwood Sound and Security Forum 2 05 Aug 2014 04:02 pm
car acting funny pryand62 Tech & Performance Forum 3 12 Jan 2013 11:14 am
My Pt Gt has been acting weird. NicksCruiser Tech & Performance Forum 19 09 Jun 2012 11:28 am
PT is acting weird when A/C is on the_jeep_now Tech & Performance Forum 13 22 Aug 2011 09:42 am
Block Heater, Rad Hose Heater, Which?? kb0nly Tech & Performance Forum 13 23 Dec 2008 03:47 pm
