2.2 CDR Engine manual
Old 19 Nov 2014, 04:34 am
Default 2.2 CDR Engine manual
Hello... what a great site for the PT....!
Just bought a PT here in the UK. 112k on the clock, but for a CDR it just run in..
My question is, is there a engine manual for this Merc lump..? I've looked in the library and found the parts and the BIG manual, just need some help on the 2.2 bit...
Oh yes... The inlet turbo hose is split so replace at eom.
also the watts link is loose so that's 2 things to sort. Also, also poly bushes will be installed at all the proper places as and when..
Regards
Mikee - UK
One of my last cars was a Nissan Skyline (GTS 33)
Old 19 Nov 2014, 04:52 am
Default Re: 2.2 CDR Engine manual
Hi, also looking for the diesel manual, s if you do come across one would you mind sending a copy my way please
2003 2.2 crd
Old 19 Nov 2014, 05:26 am
Yeah.. sure thing..!
Learning quickly about this motor...
just done an oil change.. About to do gearbox and antifreeze for the winter. You in the UK. .
Shame about the "other" forum... you have to PAY to get information..! Wonder where they got their info...!!
Next time I go to billing... I will have to give them the two finger salute...!
Regards
Mikee
Old 19 Nov 2014, 05:45 am
I also registered on the other forum till I realized I have to pay.... I'm in sunny South Africa. Been having some problems on mine, intermittent power loss. irritating as hell I can tell you.... Been trying to figure it out with no success.
2003 2.2 crd
Old 19 Nov 2014, 08:27 am
Is the engine light on..? Only 3k revs..?
On mine the inlet turbo hose is split therefore tripping a sensor and putting it into LHM (limp home mode)
it might be worth buying an OBD scanner to see what fault you got. Autolink 319 OBD on ebay.
Rub your hand round the inlet hose and see if you get oil on it or look near the alternater for oily deposits
Mikee
Old 19 Nov 2014, 08:58 am
Unfortunately I've done the dance. No leaks, no light, no limb mode, took it in to check for codes and no codes. The car is sluggish below boost, ones it hits boost it goes. Like a turbo lag. Sometimes it drives perfect, crisp throttle response, low end torque and then the next day nothing. Driving me insane.
2003 2.2 crd
Old 19 Nov 2014, 12:35 pm
Those times that it drives perfect, are you letting it run a bit before driving it? I had a friend with a turbo laser and if he just got in started it and took off it would do what you are describing. If he let it run for a few minutes first it would run great every time. He called it "turbo timing". Works both ways too. After driving let it run for a few before tuning it off.
2005 Purple Pt Touring 130k Still Running Strong
New timing belt and water pump at 130k.
Old 19 Nov 2014, 02:25 pm
Have you changed the 2 small filters..?
One on the bulkhead and one to the right of the main filter..?
I've noted the the turbo on these are not water cooled.. It is best to let it warm up a few minutes and just before shut off... The turbo still spins and if you turn off the engine it stops the oil.. Oil frying in the gullies is not good. Also 5k miles to every oil change...
Mikee
Old 19 Nov 2014, 02:27 pm
Oh yes...
You can buy "turbo timers" had one on my Skyline
Old 19 Nov 2014, 02:31 pm
Mikee
And synthetic oil is a wise precaution, also.
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
manual/auto engine sawp hotpianoplayer707 Tech & Performance Forum 17 16 Nov 2013 04:14 pm
Converting 2002 engine to a 2003 engine - ECU RomanSouthAfrica Tech & Performance Forum 2 08 Apr 2013 04:33 pm
Pt Crusier engine change with a neon engine? reepos1 Tech & Performance Forum 2 09 Nov 2010 11:21 pm
Shop Manual (service manual) DEEFIEND Tech & Performance Forum 2 17 Jan 2008 07:55 am
