Codes
Like Tree2Likes
Old 19 Nov 2014, 09:01 am
Default Codes
My grandsons 03 turbo overheated, and a/c does not blow cold. Mechanic said it needed new fan assembly and evaporator to the tune of $1,700. I have since replaced the thermostat, fan assembly, and temperature control assembly. Still overheats, since fan will not turn on.These codes appear; P0033,P0645,P0480,P0443,P0508,P0688,P1105. I went to hugginsnet.com for breakdowns and after each explanation, it read PCM may have failed. Is replacing the PCM the answer?
Old 19 Nov 2014, 09:25 am
Default Re: Codes
Please introduce yourself to the forum as soon as you can.
I would suggest working on P0480. Have you checked the radiator relays?
Old 19 Nov 2014, 10:08 am
Default Re: Codes
Have not checked relays yet. I thought that the turbo did not have separate relays and received signals from the PCM
Old 19 Nov 2014, 02:59 pm
Default Re: Codes
Oops You are right. No radiator relays.
Turbo Radiator Fan
The radiator cooling fan is a variable speed electric motor driven fan. The radiator fan assembly includes an electric motor, fan blade, and a support shroud that is attached to the radiator. The radiator fan is serviced as an assembly (fan motor/fan/shroud).
The variable speed radiator fan is controlled by the Powertrain Control Module (PCM) by way of a Pulse Width Modulated (PWM) signal. The duty cycle ranges from 30% for low speed operation then ramps-up to 100% for high-speed operation. This fan control system provides infinitely variable fan speeds, allowing for improved fan noise, A/C performance, better engine cooling, and additional vehicle power.
To control radiator fan operation, the PCM looks at inputs from:
Engine coolant temperature
A/C pressure transducer
Ambient temperature
Vehicle speed
Transmission oil temperature (automatic transmission only)
Old 19 Nov 2014, 03:34 pm
Default Re: Codes
When you replaced the fan, did the connector have the same # of pins? The '03 turbo fan is unique. (and the most expensive).
Old 19 Nov 2014, 04:56 pm
Default Re: Codes
Yes, we replaced the fan with the same number of pins. Today, we disconnected the battery and reattached it. Then we started the car and all the codes were gone except code P0688. But the fan would not turn on still.
Old 19 Nov 2014, 05:09 pm
Default Re: Codes
You might want to check and see if there is a TSB that might indicate reflashing the PCM.
Old 19 Nov 2014, 05:22 pm
Default Re: Codes
Sorry to sound stupid, but what is a tsb? Im not a pro at fixing cars, but I am trying to help save some money for my son and grandson. Thank you for all the responses
Old 19 Nov 2014, 05:51 pm
Default Re: Codes
Technical Service Bulletin
Search for TSBs 2003 PT Cruiser GT
Old 19 Nov 2014, 09:13 pm
Default Re: Codes
Engine Trouble Code P0688
Auto Shutdown Relay Control Circuit Low
Possible causes
Weak battery Low voltage while cranking
Faulty Engine Control Module (ECM) relay
ECM fuse
Faulty ECM
ECM harness is open or shorted
ECM circuit poor electrical connection
codes genet General PT Cruiser Discussions 7 08 May 2013 04:12 pm
Dash codes--not the usual OBD codes--help! chitowncruiser General PT Cruiser Discussions 5 01 Mar 2013 11:56 pm
Codes, codes, codes... Desperately need engine light help... cdc3jj General PT Cruiser Discussions 9 01 Sep 2012 07:52 am
CODES codes codes... Anyone know what these codes may mean are wrong? rksnow1 Tech & Performance Forum 10 16 Jun 2012 11:06 pm
TOO MANY CODES!!! Nonie Tech & Performance Forum 13 20 Mar 2011 12:21 am
