C.O.P. or Coil On Plug
Like Tree12Likes
Old 19 Nov 2014, 04:59 pm
UptownSport's Avatar
Default C.O.P. or Coil On Plug
As everyone knows, engines got away from distributors a few years back.
Now, the trend is to COPs, where there's no plug wire.
Here's a shot for the 2.4, using coils from the popular (in junkyards) Chrysler 2.7:
You will also need to cut & drill a plate to hold the coils in place.
Here's the story:
www.neons.org How to: Coil on plug conversion for the 2.4
This is on an aluminum valve cover, so you'll be the first to do this on a plastic cover.
What's the advantage?! I think appearance is what would most attract PT owners.
There's other COPs, 'pencil' Coils, and 'Smart' coils that are subsets of COPs, such as VW 1.8 coils, they are considered 'Smart' Coils, where the ignitor is in the coil. While you could drive this with ignitors in the the PT's PCM, it is redundant.
Old 19 Nov 2014, 05:22 pm
LionPT's Avatar
Default Re: C.O.P. or Coil On Plug
Interesrting...
Old 19 Nov 2014, 06:33 pm
Why do you say "appearance" would attract most owners. I think they are very effective with each cylinder having it's own coil and short plug wire BUT I personally hate the way all the coils on the valve covers look on the 5th, 6th and 7th generation Corvettes. Doesn't look that good on the picture of the 2.4 in your picture.
Old 19 Nov 2014, 06:49 pm
If it were cleaned up and done neat. Someone might want to have that different look. As always beauty is in the individual's eye. Thanks for the idea.
Old 19 Nov 2014, 07:23 pm
The conclusions of improved ignition spark kernel or operation are not accurate on the supplied http. There is no real performance advantage to this conversion unless you are going to use improved aftermarket C.O.P.s which are very costly.
Ultimately a better option MSD Digital ignition, Crane HI-6 multi-spark CD ignition, or a PerTronix unit.
It is a good thread and addition to the PT Forum though.
Old 19 Nov 2014, 11:31 pm
Thanks.
Neon people go for (sometimes 'perceived') function first, then appearances.
Here's a nicer looking conversion on the SOHC (PT Export/Mini) engine.
Beauty, eh?
NitroPT likes this.
Old 20 Nov 2014, 07:55 am
Originally Posted by UptownSport View Post
Thanks.
Beauty, eh?
Now that's better, I will agree but I'm afraid that unless there's a substantial advantage in doing the C.O.P. conversion, the time and money spent would be worthless and hardly ever seen under the upper intake manifold of the current 2.4 ltr PT Cruiser.
Old 20 Nov 2014, 10:24 am
The MSD DIS is a more practical and easier to install ignition upgrade than a C.O.P. for a PT Cruiser with the waste spark ignition system.
Old 20 Nov 2014, 10:47 am
Couldn't make out much on the pic. My eyes are getting to old I guess.
Old 20 Nov 2014, 11:05 am
I agree.
Wire loom is MUCH cheaper.
From what I understand, the stock ignition in good repair is quite satisfactory, not leaving a lot of room for improvement.
Cant figure this out, ignition coil? plug wires? jerseybrewing Tech & Performance Forum 14 30 Jun 2013 06:31 pm
no fire to plugs and nno voltage to plug to coil coyotesredneck Tech & Performance Forum 2 16 May 2013 03:07 am
Coil and spark plug wire question? Cyclone35 Tech & Performance Forum 5 26 Mar 2011 07:58 pm
MSD coil freetobejbp Tech & Performance Forum 6 17 Oct 2009 08:29 pm
screaming demon coil plug gap GTCOOL Stage Turbo Kits 1 10 Jun 2004 07:15 pm
