Heated Seats
Old 21 Nov 2014, 01:56 pm
Unhappy Heated Seats
My heated seats were causing a parasitic drain and killing batteries in my 2001 PT Touring. The drivers side would turn on randomly and I was able to turn off when in the PT. The heated seat must have been turning on when the vehicle wasn't occupied.
I pulled the 40a heated seat fuse from the fuse block under the hood and haven't had the problem since.
I'd like to get my heated seats back. Cold in N. Illinois.
Could the heated seat relay be the problem and where is it located(I have a spare)???
The relay is not identified on either fuse block cover.
Could it be a different problem?
Old 21 Nov 2014, 06:18 pm
Default Re: Heated Seats
The heated seat relay is located at the bottom right of the dash fuse block. If you have a right hand drive car, then it is to the left.
If the relay is bad and sticks, it could pass battery power to the heated-seat module. However the module should not pass power to the heat elements unless it or a switch for the seats is faulty.
Old 21 Nov 2014, 06:42 pm
You are not alone.
Monitor this thread and see who finds the cure first....
Heated seat malfunction
Tags
heated seat, heated seat relay
heated seats gonzomania Interior Accessories Forum 11 25 Oct 2017 11:44 am
heated seats? bryman Interior Accessories Forum 7 13 May 2012 02:53 pm
heated seats waynshar Interior Accessories Forum 2 29 Jan 2012 08:47 pm
Heated seats tswaims Interior Accessories Forum 6 31 Dec 2007 12:36 am
heated seats?? Punch General Turbo Discussions 7 09 Jan 2004 12:07 pm
