Having problems starting a 2006 Pt Cruiser
Old 23 Nov 2014, 07:36 pm
Default Having problems starting a 2006 Pt Cruiser
Ive had trouble starting up my 2006 Pt Cruiser since January of last year. It will not start up upon turning the key and it doesnt get the clicking noise. Replaced the battery and battery terminals still same result. The starter is not getting a current when I turn the key so it led me to believe it may be the either the Camshaft or Crankshaft Position Sensors since I read that a failure of either or can cause the internal computer to not send a signal so I bought new ones from my local Auto Zone. Still back to square one on trying to get the car to start. Got a copper wire and triggered a manuel start from the battery post to the starter and it gets the jump so I know that the starter works. Any help at this point is very appreciated.
2006 Crhysler PT Cruiser 2.4L SFI DOHC 4 Cylinder
Old 23 Nov 2014, 07:47 pm
Default Re: Having problems starting a 2006 Pt Cruiser
Does your engine light come on? If so what are the codes?
PT Cruisers dont like aftermarket sensors.
Old 23 Nov 2014, 07:50 pm
LionPT's Avatar
Aftermarket will work, some just don't last past a few months.
It was posted awhile back that sometimes, if the oil pressure switch is bad the car won't start...it's rare, but it does happen.
Old 23 Nov 2014, 07:56 pm
The check engine light did come on but it doesnt give off any codes on the dash.
Old 23 Nov 2014, 07:57 pm
I havent given that one a try but ill see what comes up.
Old 23 Nov 2014, 08:02 pm
I have read some had to modify new aftermarket cam sensors to get it working on PT Cruisers. I prefer Mopar sensors that I can rely on.
Old 23 Nov 2014, 08:21 pm
Im still gonna go out on a limb and say theres something wrong with the wiring starting from the relay to the starter. Maybe too much dirt in one of those areas or would i have to test each chip on the relay?
Old 23 Nov 2014, 09:43 pm
IF you get no clicking on the starter when trying to start , is the small red security light on ON? Maybe key chip is bad.
I've also had brushed hangup on the starter and one would not touch the armature with the same result as you describe. Try bumping the starter using a wooden stick on the motor part of the starter and tapping a few times with a HAMMER.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 23 Nov 2014, 09:46 pm
mityqwik's Avatar
Thumbs up Re: Having problems starting a 2006 Pt Cruiser
here's my 2cents, you replaced the battery and TERMINALS, the battery cables could be corroded inside the cable sleeves.my 06 had this happen and i rep-laced the cables and has worked great since make sure your neg.cable has a good clean ground
It takes 8,460 bolts to assemble an automobile,
and one nut to scatter it all over the road
Old 23 Nov 2014, 11:58 pm
I would suggest you get an obdII Scan Tool.
I have an 2007 and learned the hard way trying to get engine trouble codes.
If any sensors are bad they will leave a trail but you need the proper tool to get them.
2006 PT CRUISER 2.4L Turbo Problems JB13 General PT Cruiser Discussions 11 08 Oct 2014 05:49 pm
2006 PT Cruiser, Starting problems, no codes. RockCityGhost Tech & Performance Forum 5 22 Jan 2014 05:51 pm
PT cruiser starting problems mnmsforeal PT Cruiser Videos 2 03 Jul 2013 03:26 pm
2006 cruiser starting problem Cruiser54 Tech & Performance Forum 1 03 Apr 2013 05:34 pm
PT. Cruiser starting problems eddie1648 General Turbo Discussions 3 22 Jan 2013 02:32 pm
