Cruiser down
Like Tree11Likes
  • 7 Post By rob342
  • 2 Post By Busted_PT
  • 2 Post By quicksilverdon
Old 24 Nov 2014, 03:54 pm
Default Cruiser down
Hi gang , help me get this up and running. I just did a water pump and belt. I am confident the timing marks are set right but is there a way to check it without tearing the whole thing apart again?
I am not getting spark from the coil. I checked all the wiring connections and the fuses. I'm puzzled.
Old 24 Nov 2014, 04:09 pm
Default Re: Cruiser down
if you had them off, swap the cam and coil connectors. people mix them up a lot
Old 24 Nov 2014, 09:27 pm
ABSOLUTE! That was it, I swapped them around and it fired right up. Boy I'll bet that's happened boo coo times to folks not connected to the forum and had them redoing their timing. TKS !
Old 24 Nov 2014, 11:04 pm
True that. This is why I advocate to take detailed pics before you button one up. All you need do then is refer back to the pic to rule it out and move on to the next thing. I also started mine before putting it back together.
JoeX and ptcruisersteve like this.
Old 24 Nov 2014, 11:44 pm
cruserdad1976's Avatar
way to go ROB
Old 26 Nov 2014, 11:02 am
Congrats on doing the timing belt yourself and that's the only issue you had!
Old 26 Nov 2014, 09:12 pm
Dam! Good call bro. How long you been hanging around here?
2002 2.4 auto 130k and still going.
Old 27 Nov 2014, 02:01 am
If you look at the top right corner of each post, it will tell you when the person posting joined the forum.
