How to test for fuel pressure on 2.4L non-turbo?
Old 26 Nov 2014, 12:31 am
Default How to test for fuel pressure on 2.4L non-turbo?
I've been having problems starting, and want to know if it is the fuel pump relay or not. My fears are that the pump is gunked down in the bottom of the fuel tank, necessitating a replacement. Where can I check the pressure getting to the engine?
07 4-dr Touring Edition non-turbo
67k miles
Old 26 Nov 2014, 01:44 am
Default Re: How to test for fuel pressure on 2.4L non-turbo?
The fuel pump is controlled directly from the TIPM.
You should get 58 PSI average with the engine running.
Have you been getting any engine trouble codes and if so what are they?
Old 26 Nov 2014, 10:09 am
Also what symptoms are you experiencing. The more detail the better.
Old 26 Nov 2014, 10:45 am
rckstein's Avatar
67k miles
I had the fuel pump replaced recently on my PT. The symptoms that my PT had was a long crank on a cold engine. Once started, the vehicle would start fine until it sat overnight, then start again with the long crank. I took it to the dealer and they did a fuel system pressure and leakdown test that tested both the fuel pump side and the injectors. Their test didn't show anything unusual. When I was at the dealership, I noticed that they had their gauge set plugged into the fuel line connector at the firewall where the steel line that runs back to the fuel tank transitions to a flexible line to the fuel rail. However, the one test they can't do is they cannot test the flow or output of a fuel pump. It might be producing enough pressure, but may be low on volume. To me, my PT was almost acting like a check valve (if there is one) on the pump wasn't holding pressure in the line overnight, and therefore, the engine had to crank a long time to build pressure up again before it would start. After pump replacement, my PT fires right off, every time, in a few milliseconds, no more long crank!
Old 28 Nov 2014, 06:07 pm
Same symptoms as above. Extremely long cranking, and no firing whatsoever - overheated a couple of times, so there's that.
Now, would I just replace the fuel pump, or the module too?
Having a code thrown for an oxygen sensor too, the one next to the catalytic converter, so I would appreciate a diagram for that.
Old 28 Nov 2014, 06:21 pm
i would be very surprised if there was anything at all in the fuel tank as far as gunk or debris. i had to change my pump at 240,000 miles and the inside of the tank was unbelievably 100% spotless and clean. i'm a pefectionist and i was ready to clean it up in there, but it looked PERFECT inside!
ive only known of one car that had a hard start due to fuel pressure, and that was caused by the owner replacing a long portion of the steel line with high pressure rubber fuel hose. well, besides due to the valve that rckstein posted about above. that makes perfect sense.
when i pressure tested my PT, these were the results:
pressure was 56psi
from 0 to 2:00(car off), the pressure actually (very)slowly rose 2psi to 58psi
at 4:00, the pressure was still at 58 psi
after 10 minutes, the pressure was still holding 53psi.
unfortunately, the easiest way for you to do a fuel pressure test would likely be to get an older fuel rail like from a pre-2004 model so you have a schrader valve on the end of it.
for now, you might turn the key on and off a few times to prime the system and build pressure in the fuel line before you actually turn the key and start it. see if that makes a difference and let us know.
Old 28 Nov 2014, 07:06 pm
Before you think about replacing the fuel pump you need to check other things that might cause the problem.
Is it a extremely long slow cranking or extremely long fast cranking?
Old 28 Nov 2014, 08:30 pm
It starts out normal, like it was when it used to start up normally, but if you keep holding the key to ignite, it will slow down.
Old 28 Nov 2014, 08:41 pm
I would suggest you do a battery load test on the battery. The PT Cruisers are very sensitive to voltage drop. Do the load test with the battery in the PT Cruiser. Clean both battery posts and cables before taking it in for the load test.
Old 29 Nov 2014, 07:20 pm
Battery is fine, I'm sure connections might be the problem, but don't know.
Hitting the gas tank while trying to start it didn't work either. Where is the fuel pump relay on the fuse box? And where is the interior fuse box?
Clogged fuel filter, low fuel pressure or what? Gilgrin Tech & Performance Forum 8 01 Jun 2016 04:57 am
Fuel pressure problem? Brocko2 Welcome New PT Cruiser Members 13 12 Sep 2014 06:15 pm
fuel pressure check OurPTGT Tech & Performance Forum 7 27 Jul 2012 09:25 am
Fuel pressure regulator. Where it be at? Skye Tech & Performance Forum 3 23 Aug 2010 03:59 pm
Fuel pressure gauge PT GT Turbo Performance 1 14 Jun 2003 09:15 pm
