Stalls at idle. Sometimes. And rough idle
Like Tree3Likes
  • 1 Post By GrapeApe
  • 1 Post By ptcruisersteve
  • 1 Post By NitroPT
Old 26 Nov 2014, 08:51 pm
Default Stalls at idle. Sometimes. And rough idle
Got my car together last weekend. Replaced head gasket and installed stage one cams. When I had things apart I gave the IAC a very good cleaning. I have been having a big problem with it stalling out in a inconsistent manner. Tonight I had to leave town and it stalled once. Other times every time I came to a stop it will stall. Finally got the CEL on. Got a 301. Miss fire cylinder one. Put new spark plugs in last weekend and new wires about six months ago. Where should I start with this one? Any way of testing the spark plug wires?
2002 2.4 auto 130k and still going.
Old 26 Nov 2014, 11:16 pm
Default Re: Stalls at idle. Sometimes. And rough idle
The trick I have seen to do a generic test for wires/coil is to switch the wires to a different cylinders and see if you get a code for the new cylinder.
2005 Purple Pt Touring 130k Still Running Strong
New timing belt and water pump at 130k.
Old 26 Nov 2014, 11:17 pm
You can swap the ones of equal length and see if the code changes to other cylinder.
Old 27 Nov 2014, 12:14 am
jennandjudd's Avatar
while the car is running grab each plug on the coil and make sure its not shorting
Old 27 Nov 2014, 12:27 am
I would suggest checking it for an intake manifold leak. Spray WD-40, or starting fluid along the seams (upper & lower) of intake manifold by the # 1 plug - if the idle smoothing out, then it's the gasket.
boonie2 likes this.
Old 27 Nov 2014, 07:38 am
LionPT's Avatar
That's one way...to get shocked...but it will work.
Old 27 Nov 2014, 11:04 am
Very brave, or like the feeling
Been Tasered lately?
Scatgo1 your problem will considered in the PCM emissions monitoring Diagnostics and should be seen accessing the OBDII or CANbus ( depending on year PT) Diagnostic Port and checking for DTCs with a good Diagnostic Scanning Tool. You will need to note them and than clear them and drive and recheck before the problem begins and immediately after it happens. This will help rule out normal DTCs that will simply appear because of the engine stalling comparing them to DTCs not normally activated by a simple engine shutdown.
stalls at idle walruswife Gulf PT Forum 14 09 Nov 2014 07:51 pm
Rough Idle-Replacing the IAC Idle Air Controller engineerrock Tech & Performance Forum 9 07 Jun 2014 07:24 pm
2005 stalls when idle in gear or ac on no codes snapper455 Tech & Performance Forum 2 27 Mar 2012 05:52 pm
05 pt cruiser idles rough and stalls at idle wncengine Tech & Performance Forum 0 08 May 2009 10:31 am
engine stalls or stutters while in idle or stopped with a/c on, but not with a/c off traumadude376 Tech & Performance Forum 6 12 Aug 2008 12:15 am
