bad mileage with no reason why
Like Tree9Likes
Old 29 Nov 2014, 03:30 pm
Default bad mileage with no reason why
so i've been doing research and reading posts and now i am at the end of my rope. i got the coolan thing straightened out so that was not the issue. after having my timing belt and water pump changed i noticed a drastic change in my MPG. i went from arounf 240-260 per tank to about 160 per tank. you guys have any ideas why or what i can try to improve this? thanks in advance guys.
2005 Purple Pt Touring 130k Still Running Strong
New timing belt and water pump at 130k.
Old 29 Nov 2014, 04:07 pm
Default Re: bad mileage with no reason why
1) How many tanks?
2) You start you car and let it warm up before driving?
3) Check your tires - I'll bet they are low (lower temps reduce air pressure)
Old 29 Nov 2014, 04:27 pm
Originally Posted by quicksilverdon View Post
1) How many tanks?
at least 5 tanks, probably more. maybe 3-5 minutes warm up time. and i will do that tomorrow when i have some time.
Old 29 Nov 2014, 05:04 pm
i wouldn't think those things would cause a dramatic loss like that though. i could be wrong, but it seems like there may be more to it than that.
Old 29 Nov 2014, 05:39 pm
I think a combination of things. Those I mentioned, plus, winter gas formula gives poorer mileage. Engine takes longer to warm up, so car runs "richer" longer. Oil is thicker at lower temps, causing more frictional loss.
Old 29 Nov 2014, 05:52 pm
wow. didn't think it would be that much though. also, i just remembered the last time i was under the hood with it running i revved it a bit and noticed a sucking sound coming from the back of the bay kinda toward the overflow bottle for the rad. any ideas what that could be?
Old 29 Nov 2014, 06:05 pm
Your gas milage being sucke away. Check you vac hoses going into the intake manifold. Cracked exahast manifold on the N/a will cause gas milage lose.
Old 29 Nov 2014, 06:11 pm
okay. cracked exhaust would cause me to smell exhaust though, right? no exhaust smell in the bay area. ill try to get into it more tomorrow. any hoses i should look for?
Old 29 Nov 2014, 06:16 pm
Not necessarily. These a famous for cracking. Can usually see it if you remove the top heat shield cover.
Old 29 Nov 2014, 06:20 pm
ok. that's a tomorrow project. i'll take a look and let you guys and gals know. thanks
AND NOW THE #1 REASON TO COME TO SHIPSHEWANA IN JUNE Lucky7 PT Cruiser Events 1 20 May 2008 07:30 pm
New reason to love my pt! technobear General PT Cruiser Discussions 9 03 Aug 2004 07:16 pm
HELP: Alarm keeps going off for no reason jsanford Sound and Security Forum 5 14 Nov 2003 08:19 pm
