changing ECU
Like Tree3Likes
Old 30 Nov 2014, 01:18 pm
Default changing ECU
The voltage requlator aspect of my ECU would not allow my battery to fully recharge. I purchased a refurbished ECU and installed it. My car started right up. The battery is now fully charged. No error codes. Drives like a dream and the ATX shifts much better. Totally satisfied. Thanks to All Computer Exchange
Old 30 Nov 2014, 02:07 pm
Default Re: changing ECU
Some time we have other things we are not aware of going on. A good PCM can fix. Have replace one on one of mine. Good your back on the road.
Old 30 Nov 2014, 05:36 pm
Great it worked out for you.
What did it cost, and how long did it take to get it?
Old 01 Dec 2014, 11:46 pm
How did you determine is was the ECU not allowing the battery to be fully charged.
Old 02 Dec 2014, 10:06 am
[QUOTE=ptcruisersteve;548281]How did you determine is was the ECU not allowing the battery to be fully charged.[/QUOTE]
That would be great information for others to know that may have similar issues.!
Old 02 Dec 2014, 10:07 am
Old 02 Dec 2014, 01:57 pm
ya that ^^^^... ...
first 4 cylinder,it sure aint no 8....2004 2.4 base pt 5 speed manual.live wires,screeming demon coil, stage 1jet chip,strut tower bar,airraid setup..nothing fancy...NO TURBO
Old 02 Dec 2014, 05:07 pm
I determined my battery was not being fully charged by my ECU. I had to call the tow truck different times, to get a jump. Drove to Walmart and had them check it out. They tested the battery, it charged up just fine. I did some web search and found that Chryslers have a common voltage regulator problem, due to the ECU. I changed it out and everything is fine and back to normal.
Old 02 Dec 2014, 07:31 pm
How about sharing where you got it, how long it took to get, and how much???
If someone else needs one, that'd be a big help.
Old 02 Dec 2014, 08:15 pm
The where is here in his first post.
Thanks for the additional information texasjoe.
Changing Transmissions PT_Panel General PT Cruiser Discussions 2 17 Feb 2012 11:32 am
Changing TCM and PCM together Benodom Tech & Performance Forum 0 26 Dec 2010 11:35 pm
Changing PCM and TCM together Benodom Tech & Performance Forum 0 26 Dec 2010 11:22 pm
Changing out motors wareagleguy Tech & Performance Forum 2 20 Jan 2010 08:37 pm
changing oil tm05cruiser Tech & Performance Forum 1 31 Oct 2007 12:10 pm
