dropped dead
Like Tree6Likes
Old 02 Dec 2014, 07:04 pm
Default dropped dead
as I was driving today the car just stopped running leaving me without any power assists. fortunately no wreck. all electrical systems functioning and plenty of fuel. turn the key and everything is working except the starting system. not even a click from the starter. battery is new and charging system ok. it's like someone just turned the key off. is there some sort of fuse or module that controls this?.my email is is bsides45@yahoo.com
Old 02 Dec 2014, 07:16 pm
Handy_Cruiser's Avatar
Default Re: dropped dead
Let's start with some very simple diagnostics.
If you turn the key and hold it in the far position as though starting the engine, do the lights and gauges stay bright? Do they dim? Or do they go off completely until you release the key?
bsides45 likes this.
Old 02 Dec 2014, 07:17 pm
Try pushing in on key while turning it.
Radio display go out? I'm thinking bad ignition switch.
Old 02 Dec 2014, 09:31 pm
agree with the above. also check asd(?) relay.
2016 Kia Soul Plus Black
Old 02 Dec 2014, 10:13 pm
Is there a red dot lit on the dashboard?
If so does it go off when you put the key in and turn to start the PT Cruiser?
Old 02 Dec 2014, 10:40 pm
yes there is a red dot and when I turn the key power goes off. thanx for your input.
Old 02 Dec 2014, 10:43 pm
what is an asd relay. thanx for your input
Old 02 Dec 2014, 10:44 pm
yes ,it does go out. thanx for your input
Old 02 Dec 2014, 10:45 pm
Under hood by air intake
Quite sure you can swap with horn relay - then try horn and be sure it works.
Old 02 Dec 2014, 10:50 pm
What year is your PT Cruiser?
Dropped on GoldLines! Jimmy2011 Turbo Wheels/Suspension/Handling 5 01 Sep 2012 02:14 pm
2001 dropped into limp mode bobdole369 General PT Cruiser Discussions 4 02 Jun 2011 02:00 pm
Have I dropped a B*****k??? Wolfies Tech & Performance Forum 0 28 Feb 2011 01:32 pm
Dropped into 3rd gear, no power, check engine light dhtmldude Tech & Performance Forum 3 03 May 2010 02:45 pm
Need Help! Son dropped something into vents iteachcomputers General PT Cruiser Discussions 7 14 Feb 2009 10:55 pm
