Check timing?
Old 03 Dec 2014, 08:34 pm
Mik Mik is offline
Default Check timing?
Is there an easy way to check timing without taking half the motor apart? Thanks
Old 07 Dec 2014, 11:16 am
Default Re: Check timing?
yes there is
first 4 cylinder,it sure aint no 8....2004 2.4 base pt 5 speed manual.live wires,screeming demon coil, stage 1jet chip,strut tower bar,airraid setup..nothing fancy...NO TURBO
Old 07 Dec 2014, 11:31 am
If its out you may get a CEL and it will be running rough with bad gas mileage
I think to confirm timing it must come apart
What is the problem your having
When was the belt changed
When was your last tune up (Plugh, wires)
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 07 Dec 2014, 11:38 am
check lower post.....below
Timing belt went out, how can I check the valves? bobgengeskahn Tech & Performance Forum 9 12 Nov 2011 06:43 pm
Timing belt installation check from the top? worcestersauced Tech & Performance Forum 3 01 May 2011 09:33 pm
[Info req'd] Check timing and Replace intake gaskets dsmturbo General Turbo Discussions 2 21 Apr 2010 07:18 pm
