Bad Timing Belt Means Bad Top End
Like Tree11Likes
Old 04 Dec 2014, 01:31 pm
Default Bad Timing Belt Means Bad Top End
Timing belt went the other day and it seems I bent a few valves. Did not think this was a interference motor
Old 04 Dec 2014, 01:38 pm
cruserdad1976's Avatar
Default Re: Bad Timing Belt Means Bad Top End
it means that the pistons can NOT HIT THE VALVES
They can on a verry rare occasion hit each other
were you at WOT???
or maybe getting on it preety hard???
hardely ever have a case of them hitting but im sure it does sometimes
Old 04 Dec 2014, 04:51 pm
Are you doing the job or having it done?
cruserdad1976 likes this.
Old 04 Dec 2014, 05:39 pm
Great question it seems that all the mechinics seem to alwsy say OPPS YOU BENT THE VALVUES gonna cost you way more.
boonie2 likes this.
Old 04 Dec 2014, 05:48 pm
Well , funny thing I have noticed on the valve thing. Up until now, and we'll see how this is. It's been someone having it done by someone else that runs into the bent valves. One reported bent valves in every cylinder. Just not even possible. So I'm curious to see how this turns out.
Old 04 Dec 2014, 06:34 pm
boonie2's Avatar
And away we go lol
2004 Pt Cruiser 2.4 L {non turbo} 113K miles , Electric Blue pearl {PICTURES in my Profile Album}
Full Synthetic Oil 10w30 K&N Filter
Full Synthetic Trans Fluid / filter Change :bolt-away
Old 04 Dec 2014, 07:24 pm
even the parts stores call them interference engines. makes it hard to get part without funny looks around here for me.
2005 Purple Pt Touring 130k Still Running Strong
New timing belt and water pump at 130k.
Old 04 Dec 2014, 10:04 pm
Handy_Cruiser's Avatar
Here's a question. With the timing belt broke, shouldn't someone be able to pop the valve cover, rotate the cams so the valves are close on a cylinder and then do a compression test or at least a leak down test? And if you did that on all four cylinders and they checked out good, wouldn't that mean that the valves are not bent?
Seems like someone could do this before they pull the head for a valve job they very well may not need. But again, I'm not that familiar with these funny little cylinder heads.
Old 04 Dec 2014, 11:27 pm
Sounds like a good possibility to me. But as you stated not familiar with cylinder heads too much either.
Old 05 Dec 2014, 12:55 am
UptownSport's Avatar
They can't hit each other and they can't hit the piston.
It's impossible to just 'look' at an engine and say valves are bent: they are FOS
code p0300 means ?? bobs turbo pt Tech & Performance Forum 16 27 Feb 2015 09:49 pm
Timing belt shield, belt replacement. jdwalk04 Tech & Performance Forum 13 14 May 2012 10:01 am
Once again N/A means Not Applicable technobear Tech & Performance Forum 6 25 Jun 2004 10:30 am
