P0301 Code, Again
Like Tree2Likes
Old 05 Dec 2014, 02:10 pm
rckstein's Avatar
Default P0301 Code, Again
So my PT is throwing fault code P0301 - misfire on cylinder #1 again. The vehicle had a tune up last February (new plugs (stock Champion) stock MOPAR plug wires and a new MOPAR coil). Then in April when the code reappeared, the tech swapped plugs #1 and #4, but now the code is back but on the same cylinder, so that should eliminate the plug. What could be the other possible causes, or what to look at next? Thanks in advance for any help.
Old 05 Dec 2014, 02:33 pm
Default Re: P0301 Code, Again
Injector, Weak cylinder, possibly coil if never changed. I know I'll get slammed for the last thing.
Old 05 Dec 2014, 03:28 pm
Only because he replaced the coil with a Mopar coil.
Might also be intake gasket, or the ignition wire.
Old 05 Dec 2014, 03:39 pm
I did say if never changed. If n/a probobly not gaskets. If moved plug. Most likely moved wire as well.
Old 05 Dec 2014, 04:08 pm
cruserdad1976's Avatar
spray it with either or gunout while the car is running will tell you if the intake gasket is leaking or sucking air mine does the same thig has for the last 60,000 i reset it with my scanner and just drive it
Old 05 Dec 2014, 04:38 pm
rckstein's Avatar
When the tune up was first done, I had provided the tech with Champion Platinum plugs, a new NAPA coil and Granatelli plug wires. When the code reappeared, the tech went back to the stock Champion plugs because by this time, I had received information from Champion that they don't recommend their platinum plug for the PT, just their stock RE16MC. But the PT still had the NAPA coil and Granatelli plug wires. When the code came back again, removed the NAPA coil back to a stock MOPAR and replaced the Granatelli wires with the stock MOPAR wires and that's when he switched plugs #1 and #4. So everything is back to stock components.
Old 05 Dec 2014, 05:00 pm
most on here will say the stock wires are not so good i wont say cheap junk but that has been said the coil from the factory is a tank and hardely ever goes bad as far as the plugs the only ones i heard about was the coated plugs do not work good in a turbo
but with all that said id still start the car and spray starting fluid aropund the intake to see of the motor revs
Old 05 Dec 2014, 05:05 pm
i would suggest checking compression in all cylinders.
Old 05 Dec 2014, 05:12 pm
rckstein's Avatar
Compression test was done: #1 175lb, #2 170lb, #3 175lb, #4 175lb. Also a fuel system pressure test was done and the injectors were holding, no leak down overnight.
Old 05 Dec 2014, 05:29 pm
I had the exact problem a few years back. It was injector #1
P0301 help Gamer92 General PT Cruiser Discussions 11 18 May 2013 05:34 pm
P0301 code - was IAC valve Wingerbill Tech & Performance Forum 4 14 May 2012 09:54 pm
got a p0301 error code...help bkh67 Tech & Performance Forum 1 20 Jan 2011 06:34 pm
P0301 Code even with new plugs and wires? ottoman Tech & Performance Forum 3 10 Feb 2009 09:07 am
error code P0301 chicagocruiser Tech & Performance Forum 4 28 Dec 2008 06:06 pm
