The infamous clunk issue
Like Tree6Likes
Old 06 Dec 2014, 07:56 am
Default The infamous clunk issue
Hello everyone, bought my wife an 03 touring edition cruiser a month ago and it has the infamous clunk issue. It mostly happens when I turn the steering wheel and some road bumps.
I have read about the issue and it seems there are a lot of possibilities as to what specifically it could be. What can I do to isolate the issue to an area or a part instead of buying parts and installing them blind?
Thanks
Jose
Old 06 Dec 2014, 08:31 am
Default Re: The infamous clunk issue
Thanks
Jose
Front or back? The front is usually the sway bar bushings the hold the bar in place. Jack it up use jack stands for safety and shake it. if you can wiggle it, it's to lose. Check the rest of the suspension components for lose while you're there. Two things to check in the rear. The spare and the watts link. Shake these. If really lose on the center bolt or the tie rod ends on the link replace what ever is lose. If spare is lose but you can't tighten any more. You may need to lower the basket and bend the catch hook down some to get it to pull up tight.One other thing I just thought of back there. Grab the shock and shake it. I have had them be lose in the mount and rattle like that.
Old 06 Dec 2014, 08:49 am
The clunk is in the front only.
Its a clunk and it feels like somethings pops out or in place. I will check today. I just want to go straight to the source, rather than take apart more than I need to.
Thanks
Old 06 Dec 2014, 08:59 am
Thanks
Better check it pretty soon if you feel it. It has to be two things. Tie rod end or ball joint. Shake the wheel at top and bottom for a lose bearing. The grab at the sides for the tie rod ends. Rule of thumb with the tie rod ends Losen the jamb nut then count the turns that you need to screw it off and install new one to that many turns. You should be close on the alignment. If it has not been monkeyed with.
Old 06 Dec 2014, 09:14 am
Commonly, this is due to a worn rubber bushing on the front sway bar.
Old 06 Dec 2014, 09:17 am
I really wish its just that. Would I need press to replace those or no?
Thanks
Old 06 Dec 2014, 09:40 am
Thanks
you have to lift and go under the car to see if it's worn or totally gone.....replace both if they are.
Old 06 Dec 2014, 06:11 pm
Checked the sway bar bushings today and found the driver side was torn and passenger side looks spent also.
Old 06 Dec 2014, 06:18 pm
good catch!...did you check the other bushings as well while lifted?...It's no.10 on the below diagram:
Old 06 Dec 2014, 06:20 pm
Didn't check the others, down below I go again then.
Would this really cause the clunk?
That infamous gurgling from under the hood whiteclaw Tech & Performance Forum 14 18 May 2014 09:56 am
The infamous Candyman Chronicals Candyman Members PT Project 30 04 Apr 2013 11:35 pm
famous/infamous cruisers lowpt General PT Cruiser Discussions 20 22 Aug 2012 12:17 am
Question about the infamous fan motor. Elpimpe Tech & Performance Forum 3 18 Jun 2012 09:11 pm
Question for the infamous candyman cruisin03pt Wheels, Tires, Suspension 7 06 Jun 2012 08:07 pm
