cranks no fire
Old 07 Dec 2014, 04:58 pm
Default cranks no fire
2004 pt cruiser, 4 cylinder, 131,650 miles, had a shifter transmission cable freeze up, replaced cable, took me almost a month, had battery out for approx 3 weeks, put all back together, now won't start, it's cranking, but won't fire, cleaned battery terminals, checked everything over, bought new battery, installed, same out come, rented code reader, no codes ??? Help please, any ideas ? & I tried adding dry gas, fuel pump working, can hear it, getting fuel can smell it
Last edited by brendajrohr; 07 Dec 2014 at 05:27 pm. Reason: forgot other thing I tried
Old 07 Dec 2014, 05:23 pm
Default Re: cranks no fire
Spray some starting fluid in throttle body - if you have any spark, that'll make it "cough"....
Old 07 Dec 2014, 06:27 pm
I would suggest checking fuse #11 and fuse #13.
Old 07 Dec 2014, 06:52 pm
I would also look at every thing that you may have disturbed or knocked loose. When you were in there moving around.
Cranks but no start? C300392 Tech & Performance Forum 4 15 Apr 2016 07:58 am
Cranks, won't start (bad PCM ???) dxv77 General PT Cruiser Discussions 14 26 Jul 2015 05:19 pm
Cranks but want start stickkman99 General PT Cruiser Discussions 8 04 Aug 2013 12:00 am
Cranks but wont start master91599 Tech & Performance Forum 17 19 Dec 2011 02:58 pm
Cranks but don't start after TB replacement jdpersico Tech & Performance Forum 10 27 Oct 2011 03:20 pm
