Squeaky pulley?
Old 08 Dec 2014, 01:02 am
Default Squeaky pulley?
Hey guys and gals. I had my timing belt done not too long back if you guys recall. However shortly after getting Grape Ape back home, maybe a week, it started making a funny noise. I know it may be a loose/damaged/failed pulley, but I am unsure where to start. I thought it may have been power steering, as it looks the oldest i.e. rusted, so I checked the fluid level. It was fine, however the guild did seem a little foamy. The sound is like a metallic squeal. It does come from the belt side of the engine. Any ideas where I should look? Or should I just replace the pump? Thanks in advance.
2005 Purple Pt Touring 130k Still Running Strong
New timing belt and water pump at 130k.
Old 08 Dec 2014, 06:40 am
LionPT's Avatar
Default Re: Squeaky pulley?
Check your belts 1st, mainly the alternator...if that belt is too tight it will make the bearing go bad. Also check to make sure that none of them are rubbing on the timing cover.
If all looks fine, spray some water on the belts...if noise stops...you just have a loose belt.
If noise is still there, spray some WD-40 on each pulley one at a time to see if noise stops.
Old 08 Dec 2014, 09:11 am
The tensioner for the power steering is known to make the noise.
Old 08 Dec 2014, 09:42 am
Agree.
Usually belts squeal most in startup and damp conditions, bearings whenever....
Old 08 Dec 2014, 09:50 am
That would suck. It's really irritating. Makes my car sound like crap. It does speed up with the RPMs.
Old 08 Dec 2014, 10:17 am
i know what belt squeal sound like and this is not that. so i don't think i need to try that step. wish i could post audio for you guys. that would make it a lot easier to know what i mean.
Old 08 Dec 2014, 10:37 am
That's not to hard to get to. Does the noise go away with the ac on?
Old 08 Dec 2014, 11:54 am
no. it does not go away with the ac on. and i misread. i thout you said timing belt tensioner!!!
Old 08 Dec 2014, 12:44 pm
You replaced those right!
Old 08 Dec 2014, 01:04 pm
Had a kit installed so they should have. Gettin a bit worried now.
Squeaky PT Cruiser littleriver General PT Cruiser Discussions 2 22 Jan 2014 08:23 pm
squeaky bushes FireFly Wheels, Tires, Suspension 7 17 Sep 2012 09:11 am
Squeaky Brakes bjagd02 Wheels, Tires, Suspension 5 22 Mar 2012 02:23 pm
squeaky breaks. bigcitypt Tech & Performance Forum 3 18 Nov 2010 05:31 pm
Squeaky noise... slayerdarkcross Tech & Performance Forum 1 29 Sep 2009 09:19 am
