Smoking
Like Tree3Likes
Old 08 Dec 2014, 06:19 pm
Default Smoking
I have a 2004 cruiser with a 2.4 turbo, it started smoking a few months ago and was told it had a blown head gasket, had this replaced and head checked, all ok. After picking it up from shop it started smoking again within a mile, was told the only other thing it old be is the turbo, bought one had it installed and still smokes, the smoke is white or a very light gray, please help dont want to pull motor,is this my only option?
Old 08 Dec 2014, 06:24 pm
cruserdad1976's Avatar
Default Re: Smoking
No but id say you need a diffrent mechanic not being a jerk but the head gasket would be a water issue and the turbo is a oil issue a ngood mech should be able to tell the diffrence plus a leak down of the head would tell you it the Head gasket was bad but that is in the past Id say from what i have read it is most likely the turbo and id ask if they replaced the oil lines leading to the turbo--do you use synthetic oil???? did you ever get the motor in the red soze (overheated)
Old 08 Dec 2014, 06:25 pm
Default Re: Smoking
ps pulling the motor is not really a option unless you plan to just replace it whis seems to be not necessiary
Old 08 Dec 2014, 06:37 pm
Default Re: Smoking
Pull and block off the pcv valve hose to the intake. If that clears it get a new pcv valve. Let us know how it turns out. What did you do with the old turbo?
Old 08 Dec 2014, 07:04 pm
Vlefaive's Avatar
Default Re: Smoking
The wife and I smoke after sex, we're probably doing it too fast .
'03 GT Blue/ autostick.. 160,000KM ( That's 100,000miles for y'all South of the border ) All the options, the heated leather is a must up here in Canada, Love the solid heavy duty feel and obvious Torque.. The Turbo is strong, fast and reliable.. People that don't understand the love of a PT, probably don't deserve to.
Old 08 Dec 2014, 07:19 pm
Default Re: Smoking
Thanks, the old turbo is probally in the junk pile, as for the red zone no never shown over heating, and I'll try the PVC valve thingy tomorrow. Really need help with this ,so I appreciate any responses.
Old 08 Dec 2014, 07:20 pm
Default Re: Smoking
At your age you have to go fast before you forget what you were doing.
Old 08 Dec 2014, 10:01 pm
Default Re: Smoking
I would suggest checking the air filter also!
Old 09 Dec 2014, 11:17 am
Default Re: Smoking
Smell some of the smoke for oil or gas - a sweet smell is coolant.
And find another mechanic before you are broke!
Old 09 Dec 2014, 02:27 pm
Default Re: Smoking
Times two on that Don.
Recommendations for smoking Turbo jpassons General Turbo Discussions 9 20 Sep 2013 09:46 pm
smoking pt owner at wits end Lakin General Turbo Discussions 14 30 Aug 2013 09:41 pm
Heavy Smoking... Sbehm90 General Turbo Discussions 9 08 Nov 2012 12:12 am
03 tubo smoking prefesser357 General Turbo Discussions 23 11 Apr 2012 04:50 pm
Starter Smoking Swelve Tech & Performance Forum 4 14 Jan 2011 12:04 pm
