"no fuse" message
Old 08 Dec 2014, 08:49 pm
Question "no fuse" message
While out running errands today, my 2007 threw out a "no fuse" message on the odometer. It ran fine but my radio, clock, power locks, all failed. Of course, driving to the mechanic , the locks kicked in at 20 MPH and locked.
I got it to the mechanic's and left it all day. They couldn't find anything wrong. Same thing happened a few weeks ago when my motor fan wouldn't turn off and drained my battery while I was at work. Took it in, and they couldn't find anything wrong.
What gives?
Old 08 Dec 2014, 08:57 pm
Default Re: "no fuse" message
What gives?
There are reports of radio going out due to ignition switch malfunctioning, but I don't recall any report of a "no fuse" message.
Did radio come back and "no fuse" go away?
Old 08 Dec 2014, 08:59 pm
Left it at the shop all day, and now everything works. The radio and clock (digital and analog), power lock switch (inside) and keyless entry (outside) all work fine. I don't get it.
Of course my mechanic probably thinks I'm bonkers.
Old 08 Dec 2014, 09:37 pm
Here's some reading for you...
Horn and Radio Screen Intermittent?
Old 08 Dec 2014, 09:41 pm
How many miles do you have on the PT Cruiser?
Is it a non-turbo?
Has the radiator fan ever been replaced?
Old 08 Dec 2014, 09:52 pm
On your "No fuse" issue I would suggest checking the IOD fuse. It may not be making good contact. If its checks out good make sure its pushed in all the way.
Is this the first time the "No fuse" came on?
Old 31 Dec 2014, 07:27 am
have your battery checked.
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
"G" fell off my "Touring"... rockandroller The Detail Shop 19 03 Feb 2015 07:05 pm
"no fuse" light came on!!! hermtm2 General PT Cruiser Discussions 21 30 May 2014 01:15 am
no fuse message - flashing bobpitzer Tech & Performance Forum 2 24 Feb 2014 10:09 am
Turbo "phhsssss" or "whoosh" sound--Normal? Silenceable? Help! Memark General Turbo Discussions 13 24 Nov 2010 10:56 pm
