Loose Oil Filler Cap
Old 08 Dec 2014, 10:51 pm
Default Loose Oil Filler Cap
The oil filler cap has come loose on my 2006 pt engine. It just spins around inside of the valve cover instead of tightening. It seems as though I have lost the threads inside of the valve cover, although I am not sure about this. Has this happened to anyone else. Anyone know how I can fix this. Any help is much appreciated. Thanks
Old 08 Dec 2014, 11:20 pm
Default Re: Loose Oil Filler Cap
I would suggest replacing the oil filler cap.
Can you get the oil filler cap off?
Old 08 Dec 2014, 11:38 pm
I do know some filler caps once tightened as much as they should be have a click to them. So you don't over tighten them. Is it possible this click is gone and it just spins? Also as the above post asks, can you get it off?
2005 Purple Pt Touring 130k Still Running Strong
New timing belt and water pump at 130k.
Old 08 Dec 2014, 11:39 pm
soonercruiser's Avatar
Cool Re: Loose Oil Filler Cap
THIS^^^
If you can get it off, go to the local auto supply store and try a replacement.
If that works, buy it, or shop on line for a better replacement.....like a Mobil 1 cap. (You are using synthetic oil, aren't you?)
Chrysler PT Cruiser Shocker Aluminum Engine Oil Cap | eBay
Race and Street: Chrysler PT Cruiser Engine Oil Chrome Cap Cover - Kirban Performance
Frank, aka SOONERCRUISER,
Old 09 Dec 2014, 12:09 am
Thanks for the replies.
Yes I can get it off, it simply slides right out.
It does not click anymore when you tighten it, it only spins around endlessly.
The problem is that there does not seem to be a matching set of female threads inside the valve cover. Is there an insert that has broken down?
I will pick up a replacement and try it out.
Thanks again to all that responded.
Old 09 Dec 2014, 09:07 am
Sounds like you need a valve cover. The n/a is plastic and the turbo is aluminum. You need the same as you have. If you get it used it may have the cap to. This is not a common thing. So not likely this will happen again. Just don't get carried away tightening. Snug is fine.
Old 09 Dec 2014, 11:04 am
Thanks for the info. I never did crank away at it, just one click to know it was snug. I am surprised that the thread on the valve cover is so fragile.
Old 09 Dec 2014, 02:23 pm
I haven't heard of them being fragile. But some happened to yours. If you have a cheap pic and pull or some might have one here. For a good price. You can get a new gasket set very reasonable on eBay. Just make sure you get the right one n/a or turbo. They are a little different.
Old 09 Dec 2014, 04:54 pm
The only thing that should click a few times after appropriately tight, is the GAS CAP!
Oil cap should just tighten, period.
Old 09 Dec 2014, 05:16 pm
Actually they do click.
Fuel filler foam up! rstevenson General PT Cruiser Discussions 27 18 Jun 2015 06:10 pm
FILLER UP season Tech & Performance Forum 5 03 Apr 2011 03:02 pm
stuck oil filler cap syrahnose General PT Cruiser Discussions 9 08 Jan 2011 09:19 am
Filler panels ravix Exterior Accessories Forum 2 16 Apr 2007 05:29 pm
filler door pd_cruzn Classifieds: For Sale/Trade 0 19 Jul 2004 07:06 pm
