02 Parasitic Draw - Update
Like Tree3Likes
  • 2 Post By wow77
  • 1 Post By LionPT
Old 10 Dec 2014, 07:28 pm
Default 02 Parasitic Draw - Update
Just wanted to bring folks up to speed with the results of the parasitic draw problem I had.
In the previous post Lion PT was correct in his stating a bad MFS will still allow for a draw in power EVEN IF the fuse is pulled.
Here' what I did:
I used this as a guide: for disassembly
How to Repair the Multifunction Switch w/ Pictures (Fog Lights)
I followed this carefully using his soda can technique and:
-- took more pictures as I disassembled the final pieces to get to the worn pieces
- used Devco plastic welder as it too adheres to metal and plastic and this sets up rock hard in "15 minutes"
His technique and explaination "EXCELLENT"
MF switched repair
I replaced the fuse and deliberately did not start the PT for 2 days.
WOW, no diminishing of voltage over those days and it started!
Before (for years) with the fuse pulled the car wouldn't start after the second day.
Thanks for the time and those links PT Guys.
Old 10 Dec 2014, 07:32 pm
Default Re: 02 Parasitic Draw - Update
Here' what I did:
MF switched repair
Gret you fixed it. thanks for the update on the outcome.
Old 10 Dec 2014, 07:48 pm
LionPT's Avatar
In my younger years I would have torn apart & repaired like you did...
Now it's harder to see & focus on the small things, these days I would have just replaced the switch.
Good to know it all worked out...
Old 10 Dec 2014, 08:27 pm
Same here, plus I was more strapped for money when I was younger...
02 Parasitic Draw wow77 Tech & Performance Forum 19 21 Feb 2018 12:05 pm
Battery Draw Down, intermitant Parasitic? CycletoCycle Tech & Performance Forum 10 23 Jul 2013 06:51 am
Ignition-Off Draw test oldcoach General PT Cruiser Discussions 0 27 Oct 2007 04:57 am
3rd MB-5 prize draw at WILD THANG RED N BLACK General PT Cruiser Discussions 0 26 Sep 2004 08:32 pm
