no crank no start PLEASE HELP
Old 11 Dec 2014, 05:13 pm
Question no crank no start PLEASE HELP
I have a 2002 pt with nocrank no start.battery and terminal ends are clean battery tested good can cross starter sylen and it will turn over but not.start ..with key only sound is a relay under interior fuse box replaced the eletrical part of ignition switch .. how do i tell if this is security related ..please help
Old 11 Dec 2014, 05:41 pm
Default Re: no crank no start PLEASE HELP
My understanding of security system is that it will let car start, then shut it off.
Did you check cables at starter end?
Old 11 Dec 2014, 08:40 pm
Since this is your first post, how about some information on your cruiser. What mileage are we talking about?
Old 12 Dec 2014, 02:36 pm
I would suggest disconnecting the battery and reconnect. If it starts up its a possibility your Camshaft sensor needs to be checked out.
Is there a red dot on the dash and if so does it go out when you insert the key and turn the key?
You might want to check all your fuses. Especially check fuse #1 under the hood. Also check the 20 amp ASD fuse.
Check the ignition switch with the key in the start position and make sure you are getting 12 volts output.
Is the engine trouble light on? If so what is the trouble code?
Old 13 Dec 2014, 01:01 pm
Its a 02 with 179000 never any major problems installed new turn signal switch , two days later cane out no crank no start the car will not turn over with the key, batterys tested good check all connections on both ends took starter off had it tested , good reinstalled it still nothing can cross starter solenoid and will turn over with fuel and fire but will not start and key does nothing all fuses are good
Old 13 Dec 2014, 01:05 pm
Its giving about ten codes for various sensors o2, iac ,tps not reading proporly..
Old 13 Dec 2014, 02:07 pm
Seems to point to ignition switch. Key does nothing, but jumping the starter gets it to work, and connections look good...
Old 13 Dec 2014, 04:14 pm
Do you have a OBDII Scan Tool you can reset the engine trouble codes?
I would suggest resetting the engine trouble codes with the scan tool and try starting it again. Then check and see what engine trouble codes come up this time.
Old 13 Dec 2014, 04:17 pm
Check and make sure you are getting 12 volts output on the ignition switch.
Old 06 Mar 2015, 02:33 pm
hi my 2007 2.4 won't crank won't start new batter new cable new ignition switch the red light blink and new starter please help
03 No crank, No start sassylisey General PT Cruiser Discussions 11 11 Sep 2014 10:52 pm
Crank no start on 02 PT Cbdani2 Tech & Performance Forum 10 26 Aug 2014 03:31 pm
crank no start 69charger General PT Cruiser Discussions 1 13 Sep 2013 08:17 am
03 crank no start. spike General PT Cruiser Discussions 3 19 Jan 2012 08:44 am
