TIMING BELT CHANGE INTERVALS
Old 14 Dec 2014, 10:48 pm
soonercruiser's Avatar
Cool TIMING BELT CHANGE INTERVALS
I traded a few posts with a self-identified MOPAR tech on another forum, who had worked on some PT Cruisers. This happened after I had posted two recent newbie posts about valve damage after timing belt let loose; cautioning used PT purchasers to look at mileage and consider asking if the timing belt, water pump, and tensioners have been replaced.
He was totally convinced that our 2.4Ls needed changed at 60K. I posted that it is more like 80-100K.
During that exchange, I came up with a Chrysler chart on recommended intervals for timing belt changes. And, interestingly enough, a note for the 2.4L....."... (a) - Free-wheeling (Valve to Valve interference possible if camshafts are rotated independently)."
So, I'm guessing "how the belt breaks" is a contributing factor to whether there is valve damage.
I had not seen this before. Here's the link...
Timing Belt Replacement Intervals
Frank, aka SOONERCRUISER,
2011 GWE Dodge Challenger SRT8 as Show Car
Old 14 Dec 2014, 11:01 pm
Default Re: TIMING BELT CHANGE INTERVALS
2.3L* Diesel 50,000 Mi.
2.4L* DOHC (a) (2) Caravan & Voyager
2.4L* DOHC (a) PT Cruiser 102,000 Mi.
2.4L* DOHC (a) Turbo 105,000 Mi.
* - Interference engine.
1) - It is a 2.2L, not 2.3 L diesel
2) It says 2.4L* where * means interference engine, which we know is not true...
Old 14 Dec 2014, 11:02 pm
Uptown posted pics that showed at least on non running head that they don't touch. The only time we seam to get one that says bent valves is paying someone who says they have bent valves. At worst you wouldn't bend but one or two. If spinning at a high rate of speed and floating the valves. If that is possible. Ask Uptown to post his pic again and see what he thinks. Time factor and kind of driving plays a roll. Sitting for long intervals like with tires can promote dry rot and premature failure as millage goes. Oil and chemical contamination another factor. JMHO
How to know when timing belt change is a must? RacerX125 Tech & Performance Forum 5 03 Jul 2014 01:07 pm
Timing belt change - is this possible? nx13688 Tech & Performance Forum 1 14 Oct 2010 06:50 pm
timing belt change? Ginz General PT Cruiser Discussions 15 16 Sep 2010 09:16 pm
Timing Belt Change? tgibeau Tech & Performance Forum 10 07 Jun 2010 10:21 pm
Timing Belt change calflan Tech & Performance Forum 1 23 Oct 2007 03:52 pm
