Fuel Injectors - When To Replace?
Like Tree2Likes
  • 1 Post By Busted_PT
  • 1 Post By NitroPT
Old 15 Dec 2014, 08:50 pm
rckstein's Avatar
Default Fuel Injectors - When To Replace?
When to replace fuel injectors? How long should they last? I've always used name-brand fuel, except for a short while a few years ago when I used Walmart gas but I don't anymore due to some problems which I believe their fuel killed my PT's O2 sensors. I have also used periodically a fuel injector cleaner of different brand names. Everything else (spark plugs, plug wires & coil) have been replaced within the last 20,000 miles. But I have never owned a vehicle for this long or this many miles and I don't really know if it may peform better (smoother idle, better gas mileage) with new injectors? I can get new injectors reasonably priced through NAPA or Rock Auto. Thanks in advance.
Old 15 Dec 2014, 09:01 pm
LionPT's Avatar
Default Re: Fuel Injectors - When To Replace?
No need to replace them till you need to...pretty much should last life of car.
Old 15 Dec 2014, 10:06 pm
Seen them with 200k and beyond. If it ain't broke don't fix it.
rckstein likes this.
Old 15 Dec 2014, 10:19 pm
If your car is idling and running well, and gas mileage is fairly constant, there's no need....
Old 16 Dec 2014, 12:09 am
UptownSport's Avatar
I'm sure someone will claim there's did, but neon boards with 100,000's of thousands of posts don't recall reading about a bad one.
What are you going to worry about next? Crankshaft or annulus gears?
Old 16 Dec 2014, 09:19 am
I have never found a set of balanced injectors or premium spray pattern on any engine that had over 50k on it. If your wanting to get the edge on performance than yank'um and get them flowed and set balanced. It is about 100-150 at most injector shops.
Otherwise most injectors will run adequately for hundreds of thousands of miles. Our Explorer has 230K+ on the original engines fuel injectors.
RC Injectors
Fuel Injector Cleaning
Old 16 Dec 2014, 10:49 am
Once and a while I run gasoline and alcohol thru mine, keeps them clean.
Old 16 Dec 2014, 12:18 pm
so what fuel do you normally use then? In the US the gasoline fuel has a blend of gasoline and a form of alcohol or methanol already mixed.
Alcohol does not make a vary good cleaner for petroleum based products?
Old 16 Dec 2014, 07:43 pm
rckstein's Avatar
Where can I get some of these that are color matched to my PT? I tried all the local auto parts stores but they were out.
fuel injectors dunnboy Tech & Performance Forum 8 28 Feb 2012 01:28 pm
WTB Fuel Injectors for stage1 muzicmax Classifieds: Want To Buy 1 10 May 2011 10:44 am
Fuel Injectors Kawizx9r Classifieds: Want To Buy 0 13 Nov 2010 03:11 am
Stock PCM and Fuel Injectors ptcruzin42 Classifieds: For Sale/Trade 0 08 Aug 2005 07:35 pm
Fuel Injectors rzeigler@cfl.rr.com Turbo Performance 2 12 Apr 2005 08:18 am
