2002 No Spark
  • 1 Post By JoeX
Old 19 Dec 2014, 08:39 pm
Default 2002 No Spark
This is on the car that I just replaced the head gasket and Tbelt on What are the Odds ? The car was DOA when I got it here so I dont know if the reason for it quitting on her was from overheating or no spark ? This is what I have done to the car thus far, pulled the head, looked fine, new head gasket and bolts along with new timing belt and the usual when a new belt is installed. I get ready to fire this thing off and no start. Start with fuel psi check, that's good. Then on to the spark. It is getting no spark. I have replaced the coil pack, cam sync, and crank sensor, and checked for broken or shorted wires in and around the crank sensor and check all fuses. I coded it and on first codes I get P1684, P0601 and P1193 I clear the codes and disconnect the battery, reconnect and crank the engine over and see if it sets the same codes the only code it got this time is P0601. Is this thing have a dead ECM ? Im getting deep into this thing now LOL, It is beginning to become a quest now. What am I missing on this project ???
Old 19 Dec 2014, 08:59 pm
Default Re: 2002 No Spark
Did you use Mopar sensors? There are reports of some aftermarket sensors not working.
Old 19 Dec 2014, 09:25 pm
I used Borg Warner, we dont have a MOPAR dealership in town anymore. It got dark and cold so I left it for the night. To much other stuff in the shop, man I need to get some stuff done and moved so I can work inside
Old 19 Dec 2014, 10:16 pm
LionPT's Avatar
Aftermarket will work, sometimes they just don't last as long.
Old 19 Dec 2014, 10:17 pm
Often it's the wiring to the sensors.
Old 20 Dec 2014, 12:56 am
I would suggest checking your Intake Air Temperature Sensor connector and see if its damaged or it is open.
I would also check the wiring between the IAT Sensor and PCM.
If the above two suggestions are okay then I would suggest checking the IAT Sensor.
if the IAT Sensor is okay then there might be a possibility your PCM needs to be checked out. Sometimes bad sensors can make the PCM look like it needs to be replaced so you need to make sure sensors are okay first before looking at the PCM. You might want to try and find out why your system voltage is over 10.5 volts with the ignition on.
Old 20 Dec 2014, 01:29 am
The wireing connector to the cam position sensor and the coil are interchangeable. I did this to mine when changing a wireing harness.
Good luck. Merry Christmas...
LionPT likes this.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 20 Dec 2014, 09:12 am
Feel kinda silly now, my brother came up yesterday as I was finishing up and he routed the wiring harness and plugged everything back up. He nor I knew that the cam sync and the coil back shared the same connector. Soooooooo, Joe you hit the nail right on the head ! Moved the connections to the correct location, and checked for fire and it tried to start. Put the plug back in and fired her off. Runs a little rough, going to put in a new set of plugs. Now I have to install the radiator and new upper motor mount and drive it around and see how it makes out. I am still getting the P0601 code so I assume that the PCM is going to have to be replaced. Thanks guys for all the tips. Something to be said for been there done that experience !!
2002 PT Spark Plug Question tipsymcstagger Tech & Performance Forum 9 15 Sep 2012 08:44 pm
pt cruiser 2002, type of spark plugs? javolier Tech & Performance Forum 13 07 Dec 2011 04:47 pm
2002 PT Cruiser with spark problems Rhonda Welcome New PT Cruiser Members 6 15 Nov 2011 07:04 pm
Help no spark 2002 pt cruiser zackkbcobra Tech & Performance Forum 14 27 Jun 2011 03:27 pm
Spark Plugs & Wires Recommendation For 2002 Non-turbo johnjsa Tech & Performance Forum 2 19 Nov 2008 07:47 pm
