CAR STALLED AND WONT START
  • 1 Post By ptcruisersteve
Old 20 Dec 2014, 04:19 pm
Unhappy CAR STALLED AND WONT START
I was on the expressway and I heard a noise then the car stalled. I was going 70 miles an hour when it quit, the brakes raised and wouldn't work, so I had to coast on the side of the highway until it stopped. Then it wouldn't start back up. My lights still work with no dimming. I am a female and I know a little about cars but I don't have a lot of money to just buy things I think it might be. I think its the camshaft sensor but not sure. I need help please
Old 20 Dec 2014, 04:32 pm
mityqwik's Avatar
Exclamation Re: CAR STALLED AND WONT START
welcome to the forum annd from virginia . sounds to me like your timinng belt broke
It takes 8,460 bolts to assemble an automobile,
and one nut to scatter it all over the road
Old 20 Dec 2014, 04:33 pm
Default Re: CAR STALLED AND WONT START
Can you pull that sensor off? I think you broke the timing belt. Look in the hole where the sensor goes while someone tries to start it. If it turns You have a good belt . If not It broke. That can be expensive. Year and mileage?
Old 20 Dec 2014, 05:52 pm
Does the engine crank when you try starting it up?
Did you try disconnecting the battery cable, turn on the headlights, turn off the headlights and then put the battery cable back on? Sometimes if it's the Camshaft sensor that is bad it will start up and run until the PCM determines that the sensor is not working and shut the engine down again.
Is your engine light on? If so are you able to get the engine trouble codes?
Old 21 Dec 2014, 12:18 am
Yo! Shorty!
Answer and get help...
2004 PT Cruiser Stalled, won't start Jeramill Tech & Performance Forum 2 19 Jan 2013 03:46 pm
Car Wont start!! txgalant8 Tech & Performance Forum 6 06 Nov 2012 07:45 am
01 stalled, no crank, no start - thoughts? darwal61 Tech & Performance Forum 7 06 Jan 2012 06:14 pm
2001 Limited Stalled Will Not Start Macguyver General PT Cruiser Discussions 19 24 Nov 2011 11:23 am
problems (cont.) car stalled...and wouldnt start batta Tech & Performance Forum 8 13 May 2010 04:57 pm
