Another Crank Pulley Problem
  • 1 Post By Busted_PT
Old 21 Dec 2014, 07:40 pm
Default Another Crank Pulley Problem
I am replacing the timing belt on our 2001 pt sport edition. 2.4L. I have it down to removing the crank pulley, I rented the OEM puller and started cranking, everything appeared ok at first 'til it popped off the first time. I took a good look at the pulley and realized that it was coming off at an ANGLE!!! Only 2 of the teeth (3 tooth puller) had fully latched on. Now I can't get the 3rd tooth to bite. How screwed am I? Any suggestions?
Old 21 Dec 2014, 08:04 pm
Default Re: Another Crank Pulley Problem
If you get one of these 4" modle. Set it up the same as this pic. You will need to take a leg off to get all three in. Then bolt it back on. Can't pull out. You first might need to reinstall the bolt in the balancer and pull it back on a little to get it square on the shaft. If that get you going you might care for some more tips to get you through this smother.
HARMONIC BALANCER & CRANK SPROCKET REMOVEL AND INSTALL TOOL AND TIPS!!!!
Take lot of pics before and after install of the belt for references.
Handy_Cruiser likes this.
Strangest No crank problem yet Phinzor General PT Cruiser Discussions 18 21 Mar 2014 11:39 am
Stuck Crank Pulley - Bolt is Out tdf Tech & Performance Forum 6 31 Oct 2013 01:41 pm
OBX UNDERDRIVE CRANK PULLEY 03-06 PT CRUISER 2.4L TURBO ROCKETMAN8060 Tech & Performance Forum 12 16 Jul 2011 12:38 pm
Pulley Pokey Tech & Performance Forum 1 19 May 2011 02:18 pm
Under drive Crank pulley for TURBO ROCKETMAN8060 Turbo Performance 3 18 Jan 2010 05:16 pm
