No Start Need ideas
Old 26 Dec 2014, 12:36 pm
Default No Start Need ideas
The 2002 I just put a head on was running excellent, ran smoother than my wifes 2007. I have put around 50 miles on this thing seems like all was well, ran like new. The day before Christmas Eve I drove it and it developed a rough idle. Got it home didnt have time to mess with it had to go to work. Well on Christmas Eve it wouldnt start only a intermittent hit. It has fuel and spark so I thought maybe the belt jumped a tooth who knows, So I pull it all apart and it is in perfect time. I put the original crank sensor back in and the cam sync with the same results Im running out of ideas. ??????????
Old 26 Dec 2014, 01:59 pm
Default Re: No Start Need ideas
No codes? check the harness for the cam and crank harness for chaffing. Are the plugs wet? Not wet not delivering fuel. Even if you hear the fuel pump.
Old 26 Dec 2014, 03:18 pm
No codes other than the P0601, checked the connections. Plugs are wet with fuel. Next step Im getting a set of plugs just for the heck of it. Im going to do a compression check also. It make no sense, running perfectly a couple of days ago. I really cant see it having an issue with cranking compression with how well it was running. Im wondering if the PCM has taken a crap ?
Old 26 Dec 2014, 05:32 pm
Check your coil connection, may have come loose... Lets pray
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 26 Dec 2014, 06:14 pm
I had already changed the coil pack. Just put in a fresh set of spark plugs, got it to fire up, really hard starting and runs extremely rough with a dead miss at idle, still no codes other than the P0601. I thought maybe the EGR was stuck open so I made an solid aluminum gasket blocking the EGR and no change. You can bring the RPM up and it starts cleaning up around 2000 or so and runs smooth about 3000 RPM. May pull the lower intake and check for leaks there. Im still going to do a compression check on all 4.
Old 27 Dec 2014, 09:28 am
What is the cause of the lifter ( hydraulic lash adjuster ) over extending for lack of a better term, or pumping up too tight and holding the valves open slightly. This appears to be the the cause of the problem. When I put the head back on I used a set of lash adjusters from a 2003 model. As soon as I can Im pulling the cams and putting the original lash adjusters back in.
Old 27 Dec 2014, 12:41 pm
I vaguely remember someone saying the plug for the coil pack is identical to the plug that goes to the iac or something. try swapping the 2 plugs that look the same.
2016 Kia Soul Plus Black
Old 27 Dec 2014, 01:25 pm
LionPT's Avatar
Coil & Camshaft Sensor...but since his car was running, that's not it.
Old 30 Dec 2014, 02:16 pm
What else did you mess with?
If you put new head on, recheck head bolts.
Old 30 Dec 2014, 04:52 pm
Here's an update on the no start. I just got it going and have 19 miles on it.
I did a leak down and found that I all the intake valves were leaking badly, as the car was running excellent the day before I assumed that the lash adjusters were the problem. So I pulled all the rockers and air back on the cylinders and still had bad leakage into the intake tract. So off comes the head again. Once I get the head off and apart ( I didnt disassemble the head for the prior head gasket ) I find that there is heavy varnish on the intake valve stems causing them to stick partially open thus causing the leakage. I guess that when she got it hot that it baked the oil on the stems, and then again I have no idea what oil was ran it this thing for that matter. This is the first time Ive seen this happen on anything I have worked on. So I clean the valves and guides. Do a quick grind on the seats and valves and surface the head and reassembled the head. Done the usual for head replacement, hit the starter and she fired off right away ran smooth like it should.
This is something that I WILL check next time !
Any ideas?? robertpjr Tech & Performance Forum 9 28 Feb 2012 11:28 am
new ideas HELP ME!! brightlight07 Wheels, Tires, Suspension 4 06 Feb 2009 12:32 pm
New PT and looking for ideas. jplumbob General PT Cruiser Discussions 8 16 Mar 2008 08:08 pm
any ideas on where I would go?? CruiserKing Exterior Accessories Forum 9 14 Aug 2007 06:43 pm
