Stalling and dying out with no acceleration
Old 27 Dec 2014, 07:48 pm
Default Stalling and dying out with no acceleration
Hi I have a 04 pt cruiser with turbo. i bought it used. It has now 108xxx miles in it. For 3 months ive had this problem where i can ride around for hours then when the check light comes on it will stall out or at a red light die and sometimes cut back on or after a while start while pressing the gas and cranking over and over. Sometime the car will still be on but no acceleration.
Now i have replaced many things Iac senor o2 senors bc thats the code that "was" coming up. The tps, crank shaft the cam shaft the pcm the fuses and new alternator coil pk. We even took it to a mechanic who charges us $600 to change the coil pk and "figure" out what was wrong. They told us that it was the pcm so we changed that also. Nothing changed.
Today i changed the cam shaft and started a running a little better but then check light came back on and died on us at a light cranking it and pressing the gas i got it to pull of the road then noticed a smell. I did get it home after dying and restarting with engine light blinking this time. I got new code p0452. P0508 can some one please help i fell lost
Old 27 Dec 2014, 08:45 pm
LionPT's Avatar
Default Re: Stalling and dying out with no acceleration
P0452: EVAP...Evaporative Emission Control System Pressure Sensor
P0508: IAC
Old 27 Dec 2014, 09:45 pm
Yes well ive changed the iac
Old 27 Dec 2014, 09:46 pm
Do you moght know what is making the car stall and die
Old 28 Dec 2014, 07:41 am
I would suggest checking the catalytic Converter. It might be restricting your exhaust.
Old 28 Dec 2014, 04:37 pm
They were supposaly checked by the machanic that i took it to.
Old 28 Dec 2014, 05:39 pm
Did the mechanic check the fuel pressure?
Old 29 Dec 2014, 06:38 pm
They told me they did what would cause for the check engine light to come on and off. My car has been this way for over 3 months and ive drove it so i
Old 29 Dec 2014, 07:09 pm
What brand Cam sensor? PTs seem to not like non-Mopar sensors. Sometimes other brands only last a short while or don't work at all. Worth a few bucks more to get Mopar sensors.
Old 30 Dec 2014, 12:54 am
I would also suggest checking to make sure all sensors are mounted tight and secure. Make sure you don't have any loose wires going to any of the sensors.
Engine Dying? Please help. prighello General Turbo Discussions 18 25 Nov 2011 11:38 pm
HELP! MY PT KEEPS DYING OUT! ahesker Tech & Performance Forum 3 10 Jan 2010 02:44 pm
Stalling but not Dying COMTNBKR Tech & Performance Forum 4 16 Oct 2009 11:02 am
Car dying! air4cefamily Tech & Performance Forum 6 19 Jun 2008 10:09 pm
dying out ptgt General PT Cruiser Discussions 40 21 Nov 2003 05:47 pm
