PT GT Rough idle
Like Tree10Likes
Old 31 Dec 2014, 03:53 pm
Angry PT GT Rough idle
Hey guys, I'm getting error codes P0300 & P0304 (Engine misfire & Cylinder 4 misfire) but I'm not too sure what is causing this? The engine runs fine, no knocks or anything but I do notice it hiccups at times when going past 3k rpms (at full throttle) but when slowly easing into each gear it goes through 3k without "hiccuping". The car drives fine on the highway or anytime the vehicle is in motion, but when the car is idling at a stop light it has a rough idle almost like a surging idle? The engine light blinks but stops as soon as I get the car going again. The car also sucks up a lot of gas. Any ideas on what could be causing this? I've recently replaced head gaskets, ignition coil, spark plugs and the wires a month ago to "fix" this but it has not been fixed. I've tried different fuel system cleaners, gas cleaners, etc to fix it but no success. Any ideas on what could cause such problems?
Old 31 Dec 2014, 06:53 pm
Default Re: PT GT Rough idle
Did you run a compression test. Or check the valves for good seat. You might move the #4 inlector to another location to see if it is the problem.
Old 31 Dec 2014, 07:14 pm
Might be an intake gasket leak - spray starting fluid along intake manifold seams - if idle smooths out, you have an intake gasket leak.
Old 01 Jan 2015, 12:36 am
I've not run a compression test, or valves. Will put it to my to do list, but I have switched the injectors around, codes still stay with the 4th cylinder. Thanks for responding and happy new year!
Busted_PT likes this.
Old 01 Jan 2015, 12:39 am
Might have to try this too! Do you the turbo could be an issue too? Thanks for the response and happy new year!
Old 01 Jan 2015, 12:52 am
Turbo not involved here. Hopefully the intake gaskets will yield a fix. Happy New year to you also.
Old 01 Jan 2015, 02:58 am
I would suggest checking the hose for the pcv valve to intake. The hose gets rotten and sometimes has a hole in it at the elbow.
Old 01 Jan 2015, 01:01 pm
Not sure which hoes that is but I'll go through all of them! Thanks for the reply and happy new year!
Old 01 Jan 2015, 01:04 pm
That's very awesome to hear, you don't even know! I will get these components checked and or replaced! Once again thanks!
Old 01 Jan 2015, 01:09 pm
The first clue here is the P0300 DTC and not so much the P0304 at the beginning stages of searching for the problem.
*I suggest to clear the DTC using a scan tool and retest for DTC at the diagnostic port.
I would also recommend not to continue to replace or swap parts around *until you do so. You may be creating problems not already their.
The P0300 is a generic ignition trouble code that relates to just about anything that makes the engine run.
Stalls at idle. Sometimes. And rough idle scatgo1 Tech & Performance Forum 6 27 Nov 2014 11:04 am
Rough Idle-Replacing the IAC Idle Air Controller engineerrock Tech & Performance Forum 9 07 Jun 2014 07:24 pm
rough idle morgan2006 Tech & Performance Forum 0 08 Sep 2013 07:21 pm
'07 PT - Rough Idle, rough acceleration, and shuts off if it idles for too long La_Bruja Tech & Performance Forum 3 09 Aug 2013 07:50 am
Rough Idle, Rough @60, check engine light NEW Dystroy Tech & Performance Forum 8 12 Jan 2009 09:07 pm
