squeals like a pig
  • 1 Post By rob342
Old 31 Dec 2014, 04:46 pm
Default squeals like a pig
Lost some power steering fluid when I did some head work and had to remove the hose going to the reservoir. I topped it off with power steering fluid when I got thing back together and the noisees started. Just flushed out the system with atf+4 and now its worse. Time for a new pump?
2002 2.4 auto 130k and still going.
Old 31 Dec 2014, 04:55 pm
Default Re: squeals like a pig
could be air in the line. see attached. try that first. it's free
GrapeApe likes this.
Old 31 Dec 2014, 05:55 pm
Belt slipping? That'll squeal....
Old 01 Jan 2015, 10:48 am
i need to try this too!!
2005 Purple Pt Touring 130k Still Running Strong
New timing belt and water pump at 130k.
Old 01 Jan 2015, 04:32 pm
Like a Church mouse now. Thanks. Did chrysler ever decide on what we are supposed to use for power steering fluid?
Old 01 Jan 2015, 06:20 pm
Power Steering Fluid
Old 01 Jan 2015, 09:21 pm
Okay, so here is my issue. Constant squeak from pump. Fluid looks a little too full. However, when it pop the hood there I usually some fluid sitting in the little groove on top of the reservoir. I wonder if my cap might be leaking? Any ideas?
Also, I just remembered I have a few drip spots in my driveway too. But the level does not change.
Old 01 Jan 2015, 10:34 pm
LionPT's Avatar
I had a leaky cap (they are spring loaded)...the reservoir looked oily all the time...take a rag & dry it off, than check it again after you drive it next.
Cap is a dealer item, no auto parts store in town could order one.
Squeals upon starting notime0075 Tech & Performance Forum 7 12 May 2012 10:57 pm
belt squeals when car is cold? Cyclone35 General PT Cruiser Discussions 10 25 Mar 2011 05:34 pm
