Acceleration Issues?
Like Tree6Likes
Old 02 Jan 2015, 09:33 am
Default Acceleration Issues?
Hey there! I'm new so if this has been answered already I am sorry, I didn't see anything like it anywhere.
I have a 2007 PT Cruiser, Touring Edition with just over 70k. I bought it just over a month ago, has been great but something happened Wednesday and last night that is bothering me. Drove approx 80miles on HWY 24 to my moms house, pulled off my exit to a stoplight and stopped. Once it turned green I went to accelerate and my pedal was almost sticky, and then it jumped and revved and accelerated quickly and continued to do it until I got to the house and turned the car off. I thought my floor mat was sticking under my pedal so I moved it to my back seat, away from the pedal. Drove to grocery store (through 2 lights) and no issues, yay it's fixed, or so I thought. Drove it around town that night and yesterDAY and was fine. Drove back the 80 miles to my house and once I got off my exit and it started doing the exact same thing.
Both times I did use cruise control for a period of the drive, but I am at a loss as to what this could be and am a little scared to drive it even though it was fine today. Has anyone else had a similar issue? Is this something that I need to take to the mechanic today, or just watch? Thanks!
thecabinguy likes this.
Old 02 Jan 2015, 09:41 am
Default Re: Acceleration Issues?
Check the throttle body to dee if shaft or blade hanging. Lub the pivot points and a little on the cables. Clean the throttle body with some spray carb cleaner. These would be the most likely issues. If that doesn't help. Look at the gas peddle end and see if you need to do something there.
Old 02 Jan 2015, 09:48 am
Thank you! I haven't even made my first payment and was starting to get worried! I'll try this and go from there.
Old 02 Jan 2015, 09:52 am
Is it sticking and suddenly pops loose and you push it to far when this happens?
Old 02 Jan 2015, 10:00 am
No, i pressing down like normal, and it starts slow and guns (from 1rpm to about 2\2.5rpm) with no additional pressure on the accelerator.
Old 02 Jan 2015, 10:18 am
Try the stuff i said can't hurt. But I will give this some more thought. Almost sounds like pushing resume on the cruise. but you didn;t say you did that.
Old 02 Jan 2015, 10:25 am
a friend of mine had a bonneville that did the same thing. it was the cruise control. i would try taking a trip without the cruise and see if it happens again. sounds like it may just be the cruise control has a problem. the bonneville ran on vacuum and one of the lines had a leak. not sure how ours is controlled but that's just my opinion and experience. thanks.
2005 Purple Pt Touring 130k Still Running Strong
New timing belt and water pump at 130k.
Old 02 Jan 2015, 12:56 pm
I agree symptoms do sound like cruise - I think there's a fuse for cruise - pull that to be sure it cannot engage and see.
Old 02 Jan 2015, 03:16 pm
soonercruiser's Avatar
Cool Re: Acceleration Issues?
Yup! This would be the first thing to check.
Last fall, I popped-in the painted intake modesty cover for a show, and disturbed the throttle cables or a connection.
The next time I started her, she was reving out of control; tapping the pedal did nothing to change that.
Shut her off quickly; checked all connections; and worked the throttle body cables a little; all has been good since.
Frank, aka SOONERCRUISER,
2011 GWE Dodge Challenger SRT8 as Show Car
Old 02 Jan 2015, 04:17 pm
I would take off the cable cover off and work the throttle body by hand to see if was binding. But I would look for air leak around the throttle body too. Especially the air intake flex pipe..
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
acceleration issue Jaredcruiser185 Turbo Performance 10 08 Sep 2014 08:47 pm
PT Cruiser high rpms and strange acceleration issues CarNoob85 Tech & Performance Forum 9 28 Jan 2014 09:50 pm
Noise upon acceleration ncbeachchick Tech & Performance Forum 5 04 Dec 2009 07:22 am
speaker issues, wattage of stereo, door speaker replacement issues fabes89 General PT Cruiser Discussions 9 02 Jun 2009 10:59 am
Hesitation in Acceleration imduke2u Tech & Performance Forum 8 06 Jul 2002 07:36 pm
