Electric SUPERCHARGER TURBOCHARGER KIT 900 Watt Intake Turbo Cold Air Intake
Like Tree6Likes
Old 02 Jan 2015, 01:30 pm
Default Electric SUPERCHARGER TURBOCHARGER KIT 900 Watt Intake Turbo Cold Air Intake
got a 05 gt turbo convert.
anybody ever try one of these. Any info on installation would be a big
help..
BILL
Old 02 Jan 2015, 01:51 pm
Default Re: Electric SUPERCHARGER TURBOCHARGER KIT 900 Watt Intake Turbo Cold Air Intake
Comes with a bottle of snake oil....
Watts = volts x amps, so 900 watts at 12 volts = 75 amps!
Old 02 Jan 2015, 03:11 pm
soonercruiser's Avatar
Red face Re: Electric SUPERCHARGER TURBOCHARGER KIT 900 Watt Intake Turbo Cold Air Intake
SNAKE OIL!
Frank, aka SOONERCRUISER,
Old 02 Jan 2015, 03:56 pm
help..
BILL
How much?
Old 02 Jan 2015, 04:47 pm
help..
BILL
WELCOME TO THE FORUM
May I suggest that you to the new member's area and start a Hi how do you do thread and tell us a little about yourself and your PT Cruiser?
As for your 2 question Yes I have used similar ones.
I would not recommend using them as they are designed. you may not like the results.
The installation is very straight forward and in a NA PT Cruiser would only take a few hours. In a Turbo model PT Cruiser there would be location and fitment challenges.
Handy_Cruiser likes this.
Old 04 Jan 2015, 03:51 pm
interesting ...so if we aint supposed to use em their way ..what would be the way then...
first 4 cylinder,it sure aint no 8....2004 2.4 base pt 5 speed manual.live wires,screeming demon coil, stage 1jet chip,strut tower bar,airraid setup..nothing fancy...NO TURBO
Old 04 Jan 2015, 04:29 pm
The concept of the fan design and because of the dimensions do not reduce intake charge CFM caught my interest years ago.(around 1999) There is more pressure drop in the TB goose neck curve of the NA and Turbo intakes then a better quality cousin to the one mention in this thread.
If we consider that about every 30F increase in IAT reduces the HP about 4-7HP then it would best serve the engine if under a load (WOT) you could pre-cool the intake charge. The inter-coolers will only work to lower IATs if the air volume is constant other wise even larger IC's do very little to reduce the IAT.
The units tested will draw 60 amps, a PT Cruisers standard battery is over 200 cold-cranking amps and most name brand batteries can handle draws of over 100 amps while the engine is running with no problems. Look what the stock radiator fan amp draw is.
The unit tested claims a spool up to 25,300 RPM in less than 100 ms (1/10 of a second). This means it can evacuate all the static intake air out of a PT Cruisers intake manifold in about 1 second(est.).
With this I think you can figure out where from here what I do with these. And it is not anything what they sell them for!
Old 04 Jan 2015, 04:40 pm
I am NOT endorsing nor recommending that anyone use or try these on their PT Cruisers.
File picture. Only for historical interest, NA PT with a few mods K&N and E-SC.
Old 04 Jan 2015, 05:19 pm
Probably easier to use a leaf blower.
Old 04 Jan 2015, 10:38 pm
Talking Re: Electric SUPERCHARGER TURBOCHARGER KIT 900 Watt Intake Turbo Cold Air Intake
Dang! Where is the 120v outlet in my Cruiser?
Trade stock intake and new k&n drop in for cold air intake 03turbo Classifieds: For Sale/Trade 1 02 Feb 2013 08:43 pm
Electric Intake Supercharger F100BOHN Tech & Performance Forum 7 02 Mar 2010 06:20 pm
Volant cold air intake for non-turbo mopar_man Classifieds: For Sale/Trade 6 19 Jan 2010 12:24 pm
2003 TURBO UP, COLD AIR INTAKE amx1397 Vendors & Buyers Forum 1 18 Nov 2003 05:39 am
cold air intake for turbo amx1397 Classifieds: For Sale/Trade 5 26 Mar 2003 09:09 pm
