Code U0031 Problem
Old 02 Jan 2015, 01:51 pm
PTpreacher's Avatar
Question Code U0031 Problem
I have an 06 Gt with turbo and have this code coming up.
(U0031)
The person that read the code for me, said it is a failure to
communicate! Or one component not able to interact with
the main computer. It also at times will not shift out of third
gear. It is an automatic trans. You can stop and shut it off
then restart and it will work fine for extended periods of time.
We only have about 65 thous. miles on the car. Have any of
you had the same or similar problems? PTpreacher
Old 02 Jan 2015, 02:00 pm
Default Re: Code U0031 Problem
Boy, you've been away for a while!!
You certainly don't drive much.
The code indicates a low bus voltage...
Are you on original battery? Start with having battery checked - many places do it free - pick 2 and see if they agree.
Old 02 Jan 2015, 02:22 pm
PTpreacher's Avatar
Smile Re: Code U0031 Problem
Don, I am on all the time, just don't say much. Yes! I have replaced the battery.
and had it checked also. They said it was ok. ???? What else could it be?
Thanks for the reply. PTpreacher
Old 02 Jan 2015, 03:27 pm
Could be a bad ground, but I have no familiarity with your problem - sorry.
Old 02 Jan 2015, 04:39 pm
I have not had this problem but I would suggest checking the wires going to your transmission module. Make sure the connector is good and making good contact. When you have a loss of communication from one of your modules and the transmission having an issue its possible the two are related. You might want to look at your transmission solenoid and see if that is working properly.
Old 02 Jan 2015, 05:54 pm
PTpreacher's Avatar
Thanks Steve, I will check that out! Ptpreacher
Problem with Code P0481 214DallasTexas General PT Cruiser Discussions 10 03 Nov 2017 03:08 pm
help!!! code PO 0116 problem? Quicksilver Tech & Performance Forum 5 17 Feb 2014 07:45 am
2003 oil sensor problem code 522 jbander Tech & Performance Forum 2 27 Mar 2013 05:15 am
P1684 code and dONE problem jimgas Tech & Performance Forum 9 17 Sep 2012 09:55 pm
