Won't start now won't shutoff
Like Tree2Likes
Old 04 Jan 2015, 10:35 am
Default Won't start now won't shutoff
Hi
Not a newbie but back on site.
Problem is 2001 PT would not start, dash lights would stay on Check Engine,Brake, Alarm lite. Would not start. Also alarm went off by it self. Pulled battery cable it started. Had codes P1684, P1685, battery disconnect, and did not Recognize key. Used my two keys. Now at times it will not shutoff. Pulled ASD Relay, shuts down and goes back to normal. Has done this more than once???
Williamfrog
Old 04 Jan 2015, 12:28 pm
Default Re: Won't start now won't shutoff
My bet is your ignition switch is failing. When it won't start, try jiggling/pushing in on key to confirm it's switch.
Old 04 Jan 2015, 01:06 pm
Have you had anything done to the PT Cruiser before the issue with no start condition?
How long ago was the battery replaced? Have you checked the battery fluid level in the battery. On my PT Cruisers I have been checking the battery every 2 months. The PT Cruisers are sensitive to voltage drops.
Do you have a remote starter on your PT Cruiser?
Do you have any aftermarket alarm system on your PT Cruiser?
Do you have a red dot light come up and stay on when it won't start?
Have you had any wiring repaired before the problem started?
Old 04 Jan 2015, 01:10 pm
Don, Why do you think it might be the ignition switch if it starts after pulling the battery cable?
Old 04 Jan 2015, 01:38 pm
I don't think puling battery cable has anything to do with it - what else could allow it to keep running after shutting off except a bad switch?
Old 04 Jan 2015, 01:49 pm
Don, you need to read the clue "did not Recognize key". Have you had this happen to you? I have had similar problems.
Old 04 Jan 2015, 01:53 pm
Don, you need to read the clue "did not Recognize key". Have you had this happen to you? I have had it happen to me.
That could cause no start, but does it cause no stop???
Old 04 Jan 2015, 02:00 pm
Originally Posted by williamfrog View Post
Hi
Williamfrog
The statement in bold letters - Is the engine not shutting off when you take the key out of the ignition switch or is it the alarm is not shutting off when you take the key out of the ignition switch?
Old 04 Jan 2015, 02:08 pm
That is an excellent question.
I read it that engine keeps running.
Old 04 Jan 2015, 05:49 pm
Nothing done
New Battery
No remote start
Factory Alarm
Red dot yes
No wiring repair
PT Random Engine Shutoff KrisPTCruiser Tech & Performance Forum 6 01 Jun 2016 02:06 am
Will not start Eculv Tech & Performance Forum 3 09 Nov 2013 06:04 am
2002 Engine Shutoff? j_desan General PT Cruiser Discussions 5 25 Mar 2010 08:07 am
car didn't start in the cold, got jumped then was a bubbling sound and won't start Saqqara Tech & Performance Forum 1 15 Dec 2009 06:35 am
