Engine Cuts out
Like Tree4Likes
Old 05 Jan 2015, 03:37 pm
Default Engine Cuts out
So for the last few months, whenever I am on the freeway doing 60-65 mph taching around 1.5-2K, around once every couple of weeks, I will get a split second engine cut out. The needles on the speedo and tach drop immediately and then a split second later, everything is fine again.
I am discounting fuel as I would not expect the gauges to drop out like they do in a fuel starvation scenario.
No codes when I do the key dance. From what I have read, crank position sensor, cam position sensor, bad ground, bad CPU but it is so intermittant, and never on the street at 35 mph.
Any possibility a code reader might pick up something that the key dance does not?
idea?
alan
Old 05 Jan 2015, 03:46 pm
Default Re: Engine Cuts out
Nasty in that the frequency is such that it's hard to know when you've fixed it.
Inspect wiring - starting with battery terminals - and check connectors and look for wires rubbing.
Certainly can't hurt to hook up a code reader - try an AdvanceAuto, etc., they will plug inn for free.
Old 05 Jan 2015, 04:29 pm
Yes, definitely do the code reader. But you need to access the readiness files. Not all code readers can access these.
Old 06 Jan 2015, 12:00 am
What year and how many miles on your PT Cruiser?
Has there been anything replaced or repaired before the engine started cutting out at high speeds?
Old 06 Jan 2015, 12:35 am
767skyking's Avatar
Failing crank sensor
The "Three Amigos" (And Growing)
Performace, Body and Service, OEM
"Team Amigos FREE Parts!! PM me for details!!
Old 06 Jan 2015, 11:03 am
Or the wiring to it...
767skyking likes this.
Old 12 Jan 2015, 01:34 pm
115K on the odometer. Went to a convention 70 miles from the house on the freeway this past weekend. Saw the convention, driving home for about 50 miles, one small hickup, speedo drops from 62 to 5o, car shudders and then back to normal.
Could this be any more intermittant?
Old 12 Jan 2015, 08:33 pm
How long has been since the Camshaft and the Crankshaft sensors have been replaced?
Do you know what brand the Camshaft and Crankshaft sensors you current have in your PT Cruiser?
Does it seem to cut out at 2,500 rpm each time?
Old 12 Jan 2015, 08:38 pm
Vlefaive's Avatar
sounds exactly like my symptoms of failed crankshaft position sensor
'03 GT Blue/ autostick.. 160,000KM ( That's 100,000miles for y'all South of the border ) All the options, the heated leather is a must up here in Canada, Love the solid heavy duty feel and obvious Torque.. The Turbo is strong, fast and reliable.. People that don't understand the love of a PT, probably don't deserve to.
Old 12 Jan 2015, 09:11 pm
If it does seem that the engine cuts out at 2,500 rpm you might be going into limp mode intermittently. I would consider replacing the Camshaft sensor first if the engine is cutting out at 2,500 rpm.
Engine cranks, but cuts off. LemonOnWheels General PT Cruiser Discussions 4 15 Mar 2014 11:47 am
PT engine cuts out when starting with AC on mmhendrie Tech & Performance Forum 12 22 Jul 2013 10:04 pm
Engine cuts out/dies...while driving ScottS Tech & Performance Forum 2 13 Mar 2013 07:37 am
engine cuts off while driving leesa47 Tech & Performance Forum 2 19 Apr 2012 11:14 am
Engine cuts in and out at 2200 RPM tomrinsb Tech & Performance Forum 21 13 Oct 2008 04:50 pm
