2002 PT Cruiser will not start
Like Tree11Likes
Old 06 Jan 2015, 09:01 am
Default 2002 PT Cruiser will not start
My 2002 was involved in a front end collision a week before christmas. After making repairs the car will not turn over using the key. It will not even make a sound. If I jump the solenoid at the starter it turns over well but does not even sound like its trying to start. I don't believe it is getting fuel either. All ground wires and all wires are connected and all fuses are good. Please Help. Thanks
Old 06 Jan 2015, 09:30 am
Default Re: 2002 PT Cruiser will not start
I would double check the ASD fuse.
See if you are getting voltage from the ignition switch to the starter.
Old 06 Jan 2015, 10:53 am
I am not getting power to the small wire on the starter when the key is in start position.
Old 06 Jan 2015, 11:07 am
Not sure if it means anything but the red dot between the fuel and temp gauges stays lit and blinks once and stays lit with the key in the run position.
Old 06 Jan 2015, 11:50 am
Anything unplugged in the engine compartment during repairs?
Old 06 Jan 2015, 12:12 pm
What was extent of collision? Were some wires cut/pinched? Grounds could've been disturbed.
Old 06 Jan 2015, 01:12 pm
The collision was pretty fierce. Everything was above the bumper. Had to replace the whole front end. Did lots of damage to the skirts but I straightened them. It broke the power steering pump pulley and broke the top off of the starter. Once the starter broke power immediately died to the whole car. The starter wires were left just dangling for days and possibly could have grounded on something. I have no idea why the air bags did not deploy. The only thing I can think of if power died so fast to the car they may have not had time to deploy.
Old 06 Jan 2015, 05:29 pm
I think the little red dot is the security system (SKIM) key not being recognized
It gives you three chances then locks out and will not even try to start.
Key, Computer and Skim Module work together, Must be programed if any of the three were replaced.
Do you have another key with the thick grey end, try using it.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 06 Jan 2015, 07:02 pm
You know that is what I was wondering is if it were a problem with the anti theft system. The only key I have is the thick gray one. Once it locks you out what can you do to correct the problem?. I have all of the parts replaced and need to start driving the car again.
Old 06 Jan 2015, 07:29 pm
Here's one solution to a failed immobilizer
Immobilizer
2002 PT Cruiser Won't Start olegreg Tech & Performance Forum 2 13 Oct 2014 06:26 pm
2002 Pt cruiser won't start after turning it off Wfdowns General PT Cruiser Discussions 6 25 Dec 2013 08:24 am
My 2002 Cruiser won't start Racechaser Tech & Performance Forum 11 12 Aug 2012 12:42 am
2002 PT CRUISER WON'T START -98k MsLeah General PT Cruiser Discussions 9 12 Jun 2010 08:19 pm
2002 PT Cruiser will not start!!! WTF!!! thinkinboutit General PT Cruiser Discussions 3 16 Feb 2010 10:53 pm
