engine codes and problems
Old 10 Jan 2015, 03:57 pm
Question engine codes and problems
I have a 2007 cruiser, the cars rpm goes up to 4000 and speed only gets 10 if lucky, a LOT of hesitation, jerking. I have 2 codes that are prob. related to that (p0123 and p2074, not sure if p0300 is related or not)I was told to change timing belt and throttle control sensor by 2 different ppl. (I am going to do the throttle sensor test tmw by disconnecting the sensor while car is running). I was going to change sensor is car ran better. Do you suggest I change the timing belt w/water pump as well (that is expensive for parts and labor)? The cruise control quit working a couple months ago, could this be the multifunction switch or maybe related to the throttle sensor? Can someone send me some suggestions plz.
Old 10 Jan 2015, 04:13 pm
Default Re: engine codes and problems
I would suggest checking the wires and connectors on your TPS and Map sensors first before looking at replacing the TPS.
Old 10 Jan 2015, 04:46 pm
Not sure what that means....
Look for vacuum leaks - that could be both your cruise and idle problems.
Old 10 Jan 2015, 04:54 pm
How many miles do you have on the PT Cruiser?
2006 PT Cruiser, Starting problems, no codes. RockCityGhost Tech & Performance Forum 5 22 Jan 2014 05:51 pm
Auto transmission problems and codes recoveryharryp Tech & Performance Forum 5 27 Nov 2013 02:47 am
So many codes, so many problems... Is it worth it? eternalkerri Tech & Performance Forum 1 27 Sep 2013 10:49 am
Codes, codes, codes... Desperately need engine light help... cdc3jj General PT Cruiser Discussions 9 01 Sep 2012 07:52 am
Multiple Problems and error codes wwelbourn Tech & Performance Forum 3 26 Jul 2009 12:18 pm
