Need Help! 2005 Pt cruiser will not start.
Like Tree2Likes
Old 11 Jan 2015, 03:37 pm
Exclamation Need Help! 2005 Pt cruiser will not start.
First, a quick thanks to the forum, I have used this forum many times for fixes on my cruiser, I now have enough of an issue to warrant creating a thread.
So the car was running fine, no issues, we parked the car one night with it running fine. I went to leave the next morning for work and the car wouldn't start. (It was COLD, 8f) it spun for a moment and wouldn't fire but after a few tries cranking the battery became to weak to spin the engine over. At this time the check engine light lit and the car threw three codes, P0456, P0340, P0335. I'm familiar with the cam sensor code, I replaced my first one two years ago and just replaced my second one two months ago. The evap code was thrown because the gas cap hadn't clicked, I tightened it. The crank sensor was original.
I replaced the battery first as it was old and needed it. Still the car wouldn't start.
I then placed it on a scanner and cleared the codes, still no start.
I then replaced the cam sensor as it was under warranty and I had free replacement. After replacing I tried again and the car still wouldn't start. At this point I purchased a bottle of heet fuel treatment (to remove water) since the cap hadn't been tight. I then purchased and installed the crank position sensor.
All of this and now the car still won't start. I put it on the scanner again and it isn't showing any codes. I'm no longer sure where to turn, any help would be greatly appreciated. Please reply with haste, its been broke down for 3 days. Thanks again.
Old 11 Jan 2015, 03:53 pm
Default Re: Need Help! 2005 Pt cruiser will not start.
Looks like you have been doing your homework!
I would find out if you have a fuel problem or spark problem. First I would get some starter fluid and put some in the throttle body. See if starts to run.
Let us know what you find out.
Old 11 Jan 2015, 04:07 pm
Sorry should've added that, I have lightly used some starting fluid and cannot get it to fire.
Old 11 Jan 2015, 04:10 pm
Agreed. If the engine at least "coughs", you have some spark...
Old 11 Jan 2015, 04:13 pm
Guess I was typing when you posted that.
So, you have no spark - did you use Mopar sensors? Have you checked the wiring to them? (I know, codes went out, but still...)
Old 11 Jan 2015, 04:19 pm
I would suggest taking off the camshaft sensor and make sure the magnet underneath it is turning when you crank the engine over. You need to make sure your camshafts are turning.
Old 11 Jan 2015, 04:28 pm
They were not Mopar sensors, valucraft cam sensor and and iI think bdm was the maker of the crank sensor.
Old 11 Jan 2015, 04:48 pm
Do as Steve suggested - take out cam sensor and look in - if no rotation, your timing belt broke.
Old 11 Jan 2015, 06:01 pm
Thanks so much for the quick replies! I do believe the cam is spinning but I will check. It will be 5 2morrow when I'm off work be4 I can check but I will. I dropped the original bolt when I was changing the crank sensor and bought a replacement bolt that is slightly longer than the original, I'm afraid it bottomed out before fully pulling up tight to the block, I will grab a washer at work tomorrow and make sure my crank sensor is tight to the block. Is there a way to bleed the fuel line up in the engine bay? I know older cars often had a valve to bleed the line.
Old 11 Jan 2015, 09:49 pm
I had the same(ish) trouble with my 05. I came home for lunch with it running great. Got back in to go to work and all it would do is crank. It was my crank sensor. One of the things I read on here was the crank sensor can even keep it from firing. So I would make sure that is tight before anything else. Just my opinion from my experience.
2005 Purple Pt Touring 130k Still Running Strong
New timing belt and water pump at 130k.
2005 PT Cruiser won't start, Please help pfischer59 Tech & Performance Forum 4 06 Jan 2015 11:43 am
2005 PT Cruiser won't start after warmed up seas98 Tech & Performance Forum 2 21 Jan 2014 09:51 pm
2005 PT Cruiser won!t start Rudydog Tech & Performance Forum 3 06 Jan 2014 06:45 pm
2005 Cruiser suddenly wont start randyj68 Tech & Performance Forum 6 03 Sep 2012 08:28 pm
2005 pt cruiser no start fusion1620 Tech & Performance Forum 1 17 Jun 2010 05:57 am
