04 PT Cruiser, Could timing possibly be off???
Old 13 Jan 2015, 03:07 pm
Default 04 PT Cruiser, Could timing possibly be off???
We bought a used 2004 PT Cruiser around July 2014 from a small dealer ship, and since then it's been idling rough, and when you're turning the steering wheel it acts as if it wants to die out, it's got pick up and power but just those 2 things are wrong with it. We did not go back to the dealership about it because they had no garage and might have gave us problems about it and we didn't want that, So I'm here now to see what you guys could think it could possibly be, me and my dad are thinking it's going to be the timing is off, would that be what you guys think too?
Old 13 Jan 2015, 03:38 pm
LionPT's Avatar
Default Re: 04 PT Cruiser, Could timing possibly be off???
Add some fuel injector cleaner to see if that helps.
I'm not sure about the G1's (2001-2005), but I know in the G2's (2006-2010) the Power Steering Pressure Switch is used to up the idle when the pressure goes high from turning the steering wheel. Also the O2 Senors control idle...are you getting any fault codes..??
Old 13 Jan 2015, 03:42 pm
How many miles on it???
Idle is usually needing spark plugs and wires (replace both).
Injector cleaner is always a good idea, and is like chicken soup - can't hurt.
The power steering puts a load on that accentuates bad ignition.
Old 13 Jan 2015, 05:23 pm
Haven't had any codes set off yet, changed the spark plugs and the wires about 3 in a half months ago and when we pulled the 1 and 2 cylinder spark plug out they had oil on them, so we changed the spark plugs and wires and about a month later we changed the valve cover gasket and we checked the spark plugs and no oil on them at all, so we put the valve cover gasket on and the 4 o-rings on new, and put 4 new spark plugs in gaped them at 50. The oil was seeping through the back of the cylinder head out through the old valve cover gasket so that was one of the reasons we changed the valve gasket for. Put on a new PCV valve that didn't do anything, We haven't had a chance to change the oil yet because who ever had this car last must have been really stupid because we are thinking they must have either used an impact wrench on the oil drain plug or something because that bolt is close to being rounded off and really super tight, we even have special sockets that are made for bolts that are rounded but it's so tight we can't get no torque on it by hand. I'm hoping the rings ain't shot due to something the past owner did to it, the car only had about 93,000 give or take, and now about close to 98,000 miles on it, looks like a new timing belt too that's been replaced. Cold it be the upper and lower intake gaskets??? I mean when we had the upper intake off the gaskets looked okay now I know for sure on my dads PT Cruiser the both intake gaskets were totally shot they were flat totally but still his car doesn't run like mine does even before we changed his intake gaskets. So I'm puzzled I hope it's nothing major either..
Old 13 Jan 2015, 05:37 pm
Get some starting fluid, and spray along the intake gasket seams - if idle smooths out, it's the gaskets.
Old 13 Jan 2015, 05:44 pm
How would you spray starting fluid on the lower intake part connected to the cylinder head it's kinda hard to get to with everything on the engine?
Old 13 Jan 2015, 05:48 pm
Spray the area - it turns to gas immediately and if there's a bad gasket, it'll get sucked in..
Old 13 Jan 2015, 05:58 pm
Even if you can't directly spray on the lower intake down on the bottom by the cylinder head? So just spray it on the middle intake were the lower meets the upper intake?
Old 13 Jan 2015, 06:05 pm
Yes. I believe the gas is heavier than air, but I'm not positive.
Old 13 Jan 2015, 07:32 pm
I decided To watch and see what was said on this one. I think you said what best ties your thread name and your first descriptions together.
01 PT Cruiser limited edition Cold Air Intake possibly be a good idea? Bandit2014 Tech & Performance Forum 5 14 Jan 2015 11:08 pm
Electrical problems in 2003 PT Cruiser, fuses possibly jbander General PT Cruiser Discussions 52 26 Dec 2014 08:39 pm
Hello, possibly in the market for a PT GT GT_Bruiser General PT Cruiser Discussions 11 23 Sep 2012 08:08 pm
ECU codes 320 and 340, possibly bad PCM? s15xeds13 Tech & Performance Forum 4 19 May 2008 08:20 pm
Something interesting/Possibly obvious technobear Tech & Performance Forum 16 07 Jul 2004 10:46 pm
