PT Cruiser cluster electrical issue solved, might help others..
Like Tree6Likes
  • 6 Post By lwprofile
Old 13 Jan 2015, 07:02 pm
Default PT Cruiser cluster electrical issue solved, might help others..
I work on PT Cruisers once a week in our shop, and have found them to be mostly pleasing to repair. Enough so that I bought my daughter a 2005 GT Turbo, with everything, and she loves it.
To the point:
Ive spent the last two days working on a electrical issue on a 2006 Touring Edition where four seconds after turning the key on (or starting the vehicle) the gauges went dead while all the idiot lights came on and stayed on (including lights). Car ran and drove fine though.
I spent a while reading all of your threads on here and proceeded to check, clean all cables, grounds, checked computer (and reflashed), control module/fusebox, ignition elect switch, etc.
As I scanned each items communication, item by item, I finally came to the airbag module (underneath center console) and found it not to be communicating.
After removal of the console, I found it had fluid on it (maybe a spilled drink in center console, not sure).
This was the problem, and fixed it.
I hope this might help someone else, and am posting as I did not read in any of the posts on this issue that anyone checked this.
Best wishes.
Old 13 Jan 2015, 07:40 pm
Default Re: PT Cruiser cluster electrical issue solved, might help others..
Welcome.
Strange.
Probably the airbag would not have deployed if it was needed, so that's another benefit.
Very helpful first post.
Old 13 Jan 2015, 08:06 pm
Sounds like you have some good electrical troubleshooting skills. Welcome.
Old 13 Jan 2015, 09:39 pm
soonercruiser's Avatar
Thumbs up Re: PT Cruiser cluster electrical issue solved, might help others..
Well Done, Cruiser Grasshopper!
Frank, aka SOONERCRUISER,
Old 13 Jan 2015, 09:56 pm
Nice post! Thanks for posting!
Old 13 Jan 2015, 10:14 pm
To the point:
Best wishes.
Was there any engine trouble codes when you were working on this problem and if so what codes? Thanks for the information.
Help!! I have an electrical issue Destroyer4 General PT Cruiser Discussions 8 19 Jun 2015 08:23 am
*Possibly solved cranking issue*....Strangely Enough PTCruisn81 Tech & Performance Forum 2 16 May 2013 02:57 am
Charging Issue Solved Many Thanks!!!! RMoore Tech & Performance Forum 0 27 Aug 2012 04:31 pm
Cluster electrical problem? lights flash guages go right to left then out. sterioffs General PT Cruiser Discussions 0 21 Aug 2012 06:53 pm
Electrical issue? DMod General PT Cruiser Discussions 38 23 Jan 2012 08:49 pm
