really really bad fuel mileage
Like Tree11Likes
Old 13 Jan 2015, 11:28 pm
Default really really bad fuel mileage
I have a 2002 cruiser. Has around 99000 miles. I just bought the car. Was expecting around 18-20 mpg. I am only getting around 12 mpg. It's a 2.4 auto.
Old 13 Jan 2015, 11:33 pm
Default Re: really really bad fuel mileage
How many tankfuls are we talking about?
Do you let it warm up before you drive?
Have you checked tire pressure?
Hope timing belt/water pump was changed.
Welcome.
Old 13 Jan 2015, 11:34 pm
Are you getting any engine trouble codes?
Are you blowing black smoke when you first start it up?
Have you tried some fuel injection cleaner?
Old 13 Jan 2015, 11:41 pm
Tire pressure is fine. Don't think thinking belt and water pump haven't Been changed. I about 3 tanks. Still same result. There how ever is like a constant diesel ing . No engine code either.
Old 14 Jan 2015, 01:18 am
Short trips (less than 5 miles) makes my mileage drop from 18 very quickly.
If its running rough, and you just bought it, it may need at least a tune up and it would be a good time to try to find out if the timing belt was changed or its due (I wouldn't wait to long)( Timing belt gives no warning that its going to break or strip the cogs on the belt). And summer is not far off @ your mileage I would consider a new radiator cooling fan.
Since it has low mileage for a 02 the injectors may need some cleaner, and check your air filter.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 14 Jan 2015, 01:31 am
Is your engine overheating?
Old 14 Jan 2015, 11:42 am
cruserdad1976's Avatar
well 12 is wrong no matter what kind of driving you do something is not right
id say check the 02 sensor or just replace them at 100,000 that cant hurt
but there is something wrong my 06 n/a auto getts over 20 most days and i drive as hard as most
I dont like throwing parts at a problem but if there are no codes and tires are not running really low you have to start someplace
Maybe have it ran through a good ObII scanner and make sure there are no codes
Old 14 Jan 2015, 05:44 pm
soonercruiser's Avatar
Red face Re: really really bad fuel mileage
Buying a 2002 Cruiser and "expecting" the mileage on the new car window sticker, is just asking too much; really.
Post some in the "tech" Forum.
And be sure to give a lot of the vehicle maintenance history...especially plugs and wires, air filter, etc.
Frank, aka SOONERCRUISER,
2011 GWE Dodge Challenger SRT8 as Show Car
Old 15 Jan 2015, 09:50 pm
dalandon's Avatar
I get close to 100 miles per 1/4 tank, it averages to 24mpg I also drive up and down the cajon pass which is about a 2600 ft above sea level climb and around 7-8% grade, what I commonly do is reset the mpg at around freeway speeds and give it about 50-60 miles for the computer to get a approximate mpg.
2007 Pastel Yellow PT Cruiser Touring Edition Auto 4 speed, 1 of 2473
Airaid SynthaFlow Cold Air Intake 300-198
UltraGauge EM v1.2
Bridgestone Turanza Serenity Plus 195/65r15
AKA "Banana Car"
Old 16 Jan 2015, 04:41 pm
not overheating
decent fuel mileage? ptprice General PT Cruiser Discussions 15 29 Jun 2014 09:49 pm
poor fuel mileage estottlemire General PT Cruiser Discussions 50 04 Nov 2013 08:28 pm
More on fuel mileage epiquire General PT Cruiser Discussions 5 02 Oct 2013 10:19 am
Increase fuel mileage. cajunscooter2002 Tech & Performance Forum 14 29 Aug 2011 01:10 pm
BETTER Fuel Mileage for me MINIHEMI46 Turbo Performance 5 27 Mar 2008 07:29 am
