Starting troubles.
Old 14 Jan 2015, 02:28 pm
Default Starting troubles.
I have a 2003 pt cruiser non turbo. Recently after getting some body work done (Replaced the deck lid and rear bumper) I took my car to work. After work it began showing a no fuse signal on the dash. I tested and replaced the IOD which was indeed blown. Immediately after the lights in the car would not work and I found that the battery was completely dead. After replacing the battery I tried again and this time the starter only gave a single click noise and then nothing. Several days later, after testing the starter, and the alternator, I decided to just try starting the car for the hell of it, and it started and I was able to get it home from work, and then on another short trip today. The temperature has been below freezing the past few days, until yesterday when it did actually start up. What could the problem have been and how can I prevent it from happening in the future?
Old 14 Jan 2015, 02:59 pm
Default Re: Starting troubles.
Try to wigglle the cables on the battery - you shouldn't be able to move them - if you can move them, tighten the clamps.
Check the cables going to starter - if they look corroded, take connections off and clean them and retighten.
Could be starter is starting to go...
Old 14 Jan 2015, 03:23 pm
Wondering how the wiring in the lift gate was delt with?
Tags
engine trouble, no start, one click
pt troubles 05ptgirl Tech & Performance Forum 4 21 Jul 2012 12:23 pm
IAC troubles rob342 General PT Cruiser Discussions 1 16 Jun 2012 01:55 pm
06 troubles Jocko Tech & Performance Forum 4 26 Apr 2012 02:02 pm
Car Troubles PTCMIAH62 General PT Cruiser Discussions 9 07 Sep 2010 11:00 am
New guy... MBC troubles SRT Turbo Performance 3 02 Apr 2010 10:40 am
