08 PT Code P-0016 returns
Old 14 Jan 2015, 06:03 pm
Default 08 PT Code P-0016 returns >UPDATED<
I am stumped, we have spent a good bit of money this past fall getting everything up to snuff on our 08 PT and I am still having a serious issue.
P-0016
Possible causes
- Engine oil dirty
- Incorrect engine viscosity
- Crankshaft position sensor circuit is open or shorted
- Camshaft position sensor circuit is open or shorted
- Faulty crankshaft position sensor
- Faulty camshaft position sensor
- Timing gear misalign
Well, back tracking, we did the following within the last 45-60 days
New Plugs & Wires
Oil & Filter
New Air Filter
New Timing Belt, Water Pump, Pulley & Tensioner
New Drive Belts
New Cam Sensor
New Crank Sensor
New Battery
This code comes up randomly
Tonight for example.
I leave the university to head home, I get a few miles and it starts missing bad, barely accelerates and only if I sort of pump tap gingerly on the gas pedal. Takes a mile to get up to 45mph.
I get home, my guy resets the computer & now its fine again.
This has happened 3 times in the past 12 days!
I am stumped, Any ideas?
Edit,,, maybe this is a coincidence but 2 of the 4 times this has occurred it was just after going over some bumpy/rough road.
Old 14 Jan 2015, 06:47 pm
LionPT's Avatar
Default Re: 08 PT Code P-0016 returns
Check the plugs/wires to the Crank & Cam Sensors...don't wiggle them, unplug them & plug them back in.
Also is there any oil leaking from the Cam Sensor..??
Old 14 Jan 2015, 07:12 pm
Read the whole thread - don't worry about the code:
2001 pt with p0320 code
Hope it helps.
Old 14 Jan 2015, 07:18 pm
Hope it helps.
Are those wires routed the same on the 08?
Since I have no lift,, what would be the easiest way to check this,,
I assume, jack it up, right front tire off?
Or can it be seen from elsewhere?
Old 14 Jan 2015, 07:21 pm
No oil at cam sensor, the crank sensor was just installed last Saturday in hopes it was the problem.
Also,, when the mis-fire event happens, the check engine light blinks. I do not however get any mis-fire codes? I thought that was interesting in itself.
Old 14 Jan 2015, 07:45 pm
Drive it up on ramps. Plastic "Rhino ramps" are perfect for the PT. No need to take wheel off. Get a big piece of cardboard and slide under.
Old 14 Jan 2015, 08:32 pm
I wont be able to even try getting under there until at the earliest tomorrow.
Now that this has been pointed out, I wonder if when I had the belts and stuff done if they disturbed that harness & clip?
Wouldn't that be a kick in the butt?
I did all the preventative service just to be messed up by something like this?
Add in the brakes & tires & sway bar bushings we just did with the other stuff and I am in it for nearly 2 grand!
Old 14 Jan 2015, 11:15 pm
Not likely. Others have had this happen with no work having been done in the area....
Old 14 Jan 2015, 11:56 pm
I would suggest physically checking both the Camshaft and Crankshaft sensor wires going from one end to the other end. You might have a chance that the wiring on one of them is rubbing against ground somewhere.
Did you buy Mopar Camshaft and Crankshaft sensors?
Old 15 Jan 2015, 08:06 am
All Mopar parts/sensors.
Last night I drove around about 20 miles without issue. But that means nothing at this point as this has been an ongoing problem.
This car is garage kept and very clean.
Visually from the top everything looks great.
Headed to the shop in a bit, hopefully they will be able to locate the problem.
That harness in the picture, what else is going through that sleeve? Is it just the crank sensor or are there other wires present as well?
I have been having an ongoing intermittent P0420 as well.
P0420 code Converter Code? 2008/110,000 miles Sarasmiles Tech & Performance Forum 8 28 Mar 2014 07:08 pm
code 0016 missing when warm spanky911 General PT Cruiser Discussions 4 14 Sep 2013 12:59 pm
gas pedal vibration returns edb General PT Cruiser Discussions 4 28 Sep 2012 09:56 am
eror codes 0344 0016 0522 graydon1973 Tech & Performance Forum 6 24 Sep 2012 08:35 pm
PINKS: ALL OUT | Armdrop Live returns on June 5/6 2009 TMPracing Canada PT Forum 0 20 Nov 2008 03:10 pm
