Power Steering Pump Replacement - 2005 2.4 Turbo
  • 1 Post By billybob123
Old 15 Jan 2015, 12:46 pm
Default Power Steering Pump Replacement - 2005 2.4 Turbo
I've seen a few threads on here about replacing the power steering pump and the challenges of doing so. As a side note pertaining to my vehicle: I noticed it was leaking and topped off the reservoir, to find that there were still some noises coming from the area, even after topping off. The reason I suspect it's the pump and not some other hose, etc.
My question is, is it possible to replace the power steering pump without removing all the other items most often listed, on the 2005 2.4 turbo? Anyone with experience or input on this, is greatly appreciated.
Old 15 Jan 2015, 01:20 pm
Handy_Cruiser's Avatar
Default Re: Power Steering Pump Replacement - 2005 2.4 Turbo
I removed one from a turbo car at a salvage yard. And without removing the radiator and intake, I took it out through the hole where the right headlight goes. It was still fairly difficult but the headlight and radiator fan were already gone.
Old 15 Jan 2015, 01:42 pm
Thanks for the input. So you think it can be replaced, by removing just the headlight and fan? How long do you estimate it taking for removal?
So far, all the quotes for replacement are between $630-750. That sounds way over priced, considering a manuf. rebuilt pump is only $80.
On a side note: Besides the hoses, is there anything else that could be leaking? There's no doubt, something is leaking the fluid onto the ground. It's been cold & rainy, so I haven't attempted to trace the leakage.
Old 15 Jan 2015, 07:50 pm
Before doing the pump, you might consider cleaning the strainer
Power Steering Reservoir DIY
Old 15 Jan 2015, 08:29 pm
You might want to disregard this link. This link dosent apply to your PT.
y
Old 29 Jan 2016, 10:52 pm
HELLO,,,Every one
New guy to the PT world ..
I have a chance to buy a 2006 PT,,with the turbo.
My question is,,,,, The guy says it ran fine before the power steering pump was changed!!?
But now it has no power and thinks it's a TURBO issues??
Does any thing make sense to you all?
Again new to this world an looking for suggestions,,before I may buy it.
THANKS
Any Help Is A Help
Old 30 Jan 2016, 07:13 am
LionPT's Avatar
Originally Posted by Dodgedaddie View Post
HELLO,,,Every one
THANKS
Any Help Is A Help
The power steering pump has nothing to do with how the car runs...I ran mine without power steering for a month before I replaced it.
There is another problem & it sounds like he's not telling you.
Old 21 Mar 2016, 02:51 pm
When the power steering pump is removed, and the radiator fan is removed to accomplish this, some of the turbo related hoses are disconnected to create the necessary space for removing the fan. If the hoses aren't reconnected properly, the car can certainly exhibit anemic power tendencies. I learned this from personal experience when replacing my own ps pump.
Handy_Cruiser likes this.
Old 21 Mar 2016, 03:56 pm
Yep. If you hook up a temporary boost gauge, you will likely see very little if any pressure increase.
power steering pump replacement dannyces Tech & Performance Forum 8 01 Feb 2017 03:51 pm
Power Steering Pump replacement stressedPT General PT Cruiser Discussions 3 06 Jul 2014 09:30 pm
replacement power steering pump nomad327 Tech & Performance Forum 1 05 Mar 2013 06:42 am
2005 turbo Power Steering pump from places other than OEM ccspeed6 Tech & Performance Forum 0 18 Mar 2011 01:56 pm
Power Steering Pump Replacement meder2487 Tech & Performance Forum 1 04 Feb 2011 10:43 pm
